Question about Samsung RB1955 Bottom Freezer Refrigerator
Freezer temp too high
I have a Samsung bottom freezer. About two weeks ago I noticed the refrigerator door was sticking and it was getting hard to open. Now, in the last couple of days the freezer has not been cooling properly. The ice doesn't freeze, ice cream is melty, and the temp reads 28 degrees (29 after you open it) I unplugged the fridge for 10 minutes, and then plugged it back in. The fridge cooled to its normal temp quickly and with no problem, the freezer however remained and still remains at 28 degrees. I put on the power freeze to see if that would help cool it but it doesn't. I don't know what to do. My first question is, does the issue with the fridge door sticking have something to do with the freezer not cooling properly?
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Dec 24, 2009 | Samsung RF265AA Bottom Freezer French Door...
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer Drawer Stuck
Our 550 bottom freezer drawer froze shut earlier this week and the motor made an unusual sound, like it was working too hard. Two of us eventually were able to open the drawer to find that it had frozen shut due to a leak which filled the ice tray solid and then adhered to the actual door, freezing it shut. We emptied the fridge and freezer, turned the control dials down to 0, but neither the motor nor the light would go off. We finally killed the circuit breaker to get the appliance to shut down. It's cleaned and defrosted and we noticed that the gasket has torn in three places, two on the fridge door and one on the freezer door. The freezer door could be from our tugging, but the refrigerator door is normal wear and tear. We filled the tears with some kind of putty and when it is dry we will start everything up again. This is not the first problem of this nature we have experienced with our subzero 550, but it is the most dramatic. Each previous time we have called a repair man out and he has been unable to fix it.
Aug 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Samsung RB1955 Bottom Freezer Refrigerator Logo
577 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
