posted by Fittz on Apr 01, 2008
Jensen VM8511 TS will not take in any discs, the motors start to try and take a disc in, the disc makes it in about half way or so and then it spits it back out, and makes whirring noises if i just hit the eject button. The hard reset does not help either. Please save me!! haha
-Fittz
Boston, MA
Comment by Fittz, posted on Apr 06, 2008
Thanks for the help. There were like 5 pieces out of place, got all of them back except for a spring, no idea where that thing went. Was getting tired of working on it so I put it all back together and left the spring out, believe it or not, it works!
Thanks again!
Thanks again!
Best Solution
posted on Apr 01, 2008
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Comment by hogan doan, posted on Apr 26, 2008
Glad that I could help. Add me to your buddies list. I am experienced with many electronic and mechanical problem. If I don't know how to fix it then I can refer to different sources that will help. Thank you.
Rating Locked! (?) Fittz has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Jensen VM9511TS AM/FM/CD/DVD/SD
Email this problem
Email this problem
Can you Help with these Car Video Players problems?
Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD...
sd drive
sd drive
can anyone tell me why my sd... Answer This...
wont turn on
wont turn on
my jensen vm9511ts show a red... Answer This...
Road noise
Road noise
I have a 04 f150. My system... Answer This...
dvd receiver
dvd receiver
need code to unlock stereo deck Answer This...
problem with remote
problem with remote
I have a jensen vm9311 in dash... Answer This...
Repair Service
Find Car Video Player Repairman Near You:
