Midi Problems Casio PX-575R
Casio Keyboard PX-575R will not work with MAC using the USB Cable.  What do I need to get it to work?
Check this out.  http://code.google.com/p/casiousbmididriver/wiki/Compatibility
Posted on Feb 08, 2009
Corrupt data
PX 410r uses IDES 4.0 downloadable from
http://www.casio-europe.com/euro/emi/specials/ides/downloads/
and not another version.
I suggest you uninstall the Casio USB driver from Control Panel'system'device manager then Reboot the PC without the USB cable.
Download latest USB driver from :-
http://support.casio.com/en/support/download.php?cid=008&pid=20
64 or 32 bits versions are both available.
Load driver first. Plug in the usb cable only when software tells you to do so.
Uninstall Data manager if wrong version.
Install IDES 4.0
Mar 08, 2014 | Casio Music
What kind of USB cable do I need for my CTK-491 Keyboard, and where can I find it?
You will need MIDI cable - widely available from good musical instrument (keyboard) stores and on the internet
For more information about using MIDI on your keyboard see the appropriate section in teh user's manual here http://support.casio.com/pdf/008/ctk_491_01_e.pdf
Feb 10, 2011 | Casio Ctk491 Midi Keyboard
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Is there a "Factory Reset" procedure for a Casio Privia PX-575R
Here is a link to the manual:http://ftp.casio.co.jp/pub/world_manual/emi/en/PX410R_e.pdf Page E-79 describes the procedure. Here is a link to their support page in case you don't have the CD that was bundeled with the keyboard:http://www.casio.com/support/
Oct 17, 2010 | Casio Privia Keyboard Case
Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Jan 21, 2010 | Casio Privia Keyboard Case
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
LOST MY CASIO WK-110 INSTALLATION CD
I was successful installing a Casio Privia PX-575R USB midi keyboard to Windows 7 Ultimate x64!!!
I tried to use Yamaha, Korg, M-Audio, and some other drivers I don't remember and
they did not work.
I then downloaded the win 7 x64 driver for PC-50 from
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=PC-50&iRcId=16224976&dsp=1
(but I bet any of them would work) from Roland. All I did was change the hardware ID
in the INF file under
[Roland.NTamd64.6.1]
;; Windows7
%RDID0053DeviceDesc%=RDID0053Install, USB\VID_07CF&PID_6802
The ID is after the comma and the one you see above is from the Casio keyboard i have. The
hardware ID for your keyboard can be found in "device manager". Just choose your
hardware/keyboard and go to "details" and choose "hardware id" from the drop down
menu and put that after the comma. It will start with "USB" since it is a usb
devise. There may be more than one ID but the first one works for me. Then just do
a manual install by right clicking "computer" or "my computer" and click "device
manager" tab. Then find your keyboard (probably a yellow exclamation mark next to
it) and double click it. Then go to the "driver" tab and click "update driver".
Then choose "Browse my Computer for driver software", then "Let me pick from a list
of device drivers on my computer", then "Have Disk..." and browse for the INF file
you just put the hardware ID in and click "open".
You now have a working Casio keyboard for a 64 bit or x64 windows 7 operating system.
You can do the same with Vista x64 or XP x64, just download those drivers and edit the hardware ID the same way.
Thanks
Mar 24, 2009 | Casio WK110 Portable Keyboard
Audio drivers
This may be too late, but,
I was successful installing a Casio Privia PX-575R USB midi keyboard to Windows 72_bing.gif Ultimate x64!!!
they did not work.
;; Windows7
it) and double click it. Then go to the "driver" tab and click "update driver2_bing.gif".
of device drivers2_bing.gif on my computer", then "Have Disk..." and browse for the INF file
You can do the same with Vista x64 or XP x642_bing.gif, just download those drivers and edit the hardware ID the same way.
Thanks
Jan 28, 2009 | Computers & Internet
210 people viewed this question
 Grubhead
Grubhead
