Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
Will not take in any discs
It will not take in any discs, the motors start to try and take a disc in , the disc makes it in about half way or so and then it spits it back out, and makes whirring noises if i just hit the eject button. The hard reset does not help either. Please help!!
  • 1 more comment
  • gjd4u2nv Dec 23, 2008
    the same problem here as well. gears sound like they are struggling to take in disc. This PISSES me off bc i paid 800 dollars for this thing and I barely used it at all for movies or CD's and now its broke! Help!
  • jgmarine83 Jan 28, 2009
    It will not take any disks even when I reset it. When it would take them it would lose its place on the disk after turning off my truck. Cd's would not skip but my dvd's would.
  • ch3vyboi305 Feb 06, 2009
    It will not take in any discs, the motors start to try and take a discin , the disc makes it in about half way or so and then it spits itback out, and makes whirring noises if i just hit the eject button. Thehard reset does not help either. Please help
    Champion:
  • 227 Answers
Best Solution posted on Apr 01, 2008 Will not take in any discs - 4%20stars.png
hogan doan
Posted on Apr 26, 2008
SOURCE:
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
"No Disc" error message
A no disc error on any electronics device indicates one of three problems. 1. The disc reading lens in the cd/dvd/brd drive has gone out or is dirty. 2. The drive has a "stabilizing" screw that must be tweaked. 3. The disc is not spinning due to a bad motor on the drive or something is blocking it. If you can hear the disc spinning *whizzing sound* its not a motor issue. You can try running a cd lens cleaning disc but if its not registering it probably wont spin, thus wont clean the lens. You can attempt to clean a lens with a cotton Q tip and rubbing alcohol but be warned, touching the lens can scratch it and destroy it. If your object is not under warranty you can have a professional look at the drive to check the tension on screws, this is usually a huge problem found in XBOX 360's. Make sure its not the disc by trying other working games/movies/etc. If all else fails you can always purchase a new dvd/cd/blu ray drive and have it professionally installed. Xbox 360 $20-$40, PS3 $100-$150 Although its not common, another solution is that cables on the drive might be loose, but usually you cannot open the device; the two cables are power approx. 1-1.5 inches long and the output plug which is usually half the size.
Jan 09, 2011 | Video Game Consoles & Games
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
The Memorex DVD player makes clicking and either it stops playing or plays in fits a starts - It does this more than half way into the disc
That sounds like the traverse motor is having problems turning and moving the laser further out into the disk.
Check there is not a speck of hard dust on the traverse motor mechanics, cogs etc.
Oct 19, 2010 | Televison & Video
Disc loads, makes click click sound then message no disc
that click click is the laser trying to focus and it is hitting the disc.
the biggest failure is the disc motors.they are very tiny motors and if they do not spin fast enough,the laser can not get the info it needs.
sometimes banging on it lightly while it is focusing will get the disc to spin.
with the price of new ones,it is not worth repair.
that is why i got out of the repair biz in 1995
May 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9511TS : Doesn't take in discs
It sounds like a mechanical error. It's not a quick fix. You (or more likely a repair shop) would have to pull the transport and reallign a bunch of parts and possibly resurface the rollers. It's a GIANT pain in the @$$.
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Car Audio & Video Logo
164 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
