Question about Philips Magnavox 27MS343S 27" TV
Capasitor Thanks for your help. We are having trouble finding the capasitors needed though. My father in law says they have to be AC and Radioshack only has DC. I've looked online for them and my father in law is going to check out what I found tomorrow, but none say if they are AC or DC. Do you know of a good place online to order them? Thanks again.
  • oilfieldwife Apr 06, 2008
    Thank you SO much for your help. We were quoted up to $600 from repair shops to fix our tv and thanks to your help we fixed it for less than $15. Thanks again!
    Sergeant:
  • 395 Answers
Electrolitic capacitors can be used in dc and ac circuits as long as you know how to use them. basicly a cap is a fast charging and discharging battery. it is designed to hold charges steady in a cicuit. they have a positive side and a negitive side. donot reverse the polls or you will have an exploding cap. the cicuit that these caps are in is a dc cicuit (24 volts to the panel).
the caps again are 2200uF 35 volt with a temprature rating of 105 degrees C.
you can get them at www.mcminone.com part number 31-5745. remember DONOT REVERSE THE POLLS!! there is a strip down the side with negitve signs in it that corespond to the negitive lead. the board will have the polls printed on it or at lest om of them.
Posted on Apr 01, 2008
I have an LG front load washer and I can't start the machine, the power button will not respond. I have power to the unit because the interior drum light has stayed on. Any suggestions?
The starting capasitor on the motor could be faulty. If this happens the machine would not start running. A method to check if it is the starting capasitor, is to open up the washing machine covers and once the button is pushed - give the motor a turn by hand to see if it starts running. This should only be done by a qualified person as it is dangerous if you do not know what you are doing.
If the washing machine motor starts running, then the capasitor if faulty and needs to be replaced,
Trust this will help you.
Regards
Andre
Nov 02, 2017 | LG Washing Machines
What size run capacitor do i have to get for a mitsubishi muh12tn
Best thing to do would, is look at the one that is currently inside of it, and just find a local Ac supply house, and take the capasitor with you and purchase a new one, Normaly if you look at the numbers on your current capasitor it will have the number with a UF just to the right of the number.
Nov 05, 2013 | Mitsubishi MSH12TN Air Conditioner
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Oct 18, 2013 | Bosch Classixx WFC 2465 Front Load Washer
Reverse rotatin on fan motor aire flo air conditoning model #20402077insol knew capasitor 3 tipe capasitor capasitor /hern/fan/c/
When the capacitor goes bad it can cause the fan motor to run backwards, the capacitor needs replaced.
Sep 24, 2011 | Carrier 38CKC036 Air Conditioner
Motor wont start but runs without the belt on
replace the new capasitor,the capasitor is placing near the motor,unplug the unit before remove it and be carefull to touch the pin of the capasitor coz of high voltage,check the micro farad of capasitor and buy a new one,,but sometime the motor also problem if the motor have water mark is means replace the motor of new one,but ask the price of new one if is expensive try to buy a new one with 1warranty compare the motor you buy is only 1month warranty.
Dec 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My rudd ac quit working opened panel and found black round part is blowout
Hello That is the START capasitor,disconnect it & get and install a HARD START KIT on the run capasitor.It is a simple 2 wires that plug on the run cap and will do the job of the defective factory one.
Aug 28, 2010 | Weather King 10AJA4201AH Air Conditioner
Found problem but need to know capasitor
Check this page on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ We have repair guides for all three versions of the Dell E173 monitors. If you need any additional information just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Dryer wont start, checked power source good. checked door switch good, checked thermal fuse good, what next?
Possible capasitor faulty. But be very carefull when checking capasitor as they hold power even when off. The capasitor stores power to start your motor running.It is normally situated close to the motor. If you remove this then although machine is unplugged you should discharge power from capasitor by shorting it with suitable screwdriver before touching it
Mar 15, 2010 | Dryers
Intertherm 3 ton ac unit I took the capasitor off to get a new one and forgot how to wire it it is not on the cover three wire fan and compressor three prong 55-5 capasitor help
The 55 terminal is marked "herm" it goes to the start winding of the compressor. The 5 terminal is marked "fan" it goes to a wire from the fan motor. The common terminal goes to one side of the power line...The side that is NOT going directly to the compressor.
Jul 27, 2008 | Intertherm Heating & Cooling
PART NUMBER
C861 is a 1000PF 25V capacitor
Oct 06, 2007 | Panasonic PV-DF2703 Triple Play 27 in....
Philips Magnavox 27MS343S 27" TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
