Audio 99 cougar?
99 merqury couger radio power dosnt turne on after i changed the battary? should i have any code eaven the power dosnt turne on?
help!
  • joedaly72 Apr 02, 2008
    Than You excellent.
    but it asking me for code!!for the radio cd to works!!
    what is that code ?how can i get it?
    it is merqury 1999 cougar V6 oreginal audio
    Thank you again for your help
    Scholar:
  • 130 Answers
You may have blown a fuse, check the radio fuse or cigarette lighter fuse under the dash and see if there are any bad ones, you should have a diagram of what fuse is which on the fuse box cover. check the cigarette lighter and see if its out too, they might not share the same fuse but a lot of times they do. you might have to take each one out one at a time to see if they are bad, if one is bad there will be a little break in the metal in the middle on the fuse. hope this helps!
Posted on Apr 02, 2008
  • Bryan Lee
    Bryan Lee Apr 03, 2008
    you may be able to take it into a ford dealer and get the unlock code, my father inlaw had the same problem and thats what he did. honda didnt charge him so you might give that a shot. i really dont know why they started putting those codes on the stereos, its not going to stop a thief from taking the radio, it will just keep him from using it. lol. yea try taking it into a dealer and see what they tell you, they should have the codes and shouldnt charge you to get them since you have the whole car and not just the stereo. good luck and let me know what they say
I HAVE A 99 6 CYLENDER COUGER AND IT HAS NO RESPONSE FROM THE KEY NO LIGHTS COME ON NO POWER TO ANYTHING CHECKED THE BATTERY AND ITS GOOD IS THIS PROBLEM COMMON AND HOW DO I FIX IT???
Sounds like the battery cables are loose or corroded.
Usually its the battery. But your saying battery is ok.
Is battery new?If no was battery load tested?
Battery cables can be for resistance with a voltmeter.
If you need help with that let me know.
May 19, 2010 | 1999 Mercury Cougar
Alternater wont charge battery in my 99 mercury couger
is your serpentine belt loose or worn? also check idler pulley tension..
Apr 25, 2010 | 1999 Mercury Cougar
Well i have a 99 couger and i had to replace the pcm so took it to ford dealer had the car re programed so it would start now when i put it in drive it takes off in high and want shift up or down and speed...
most likely you need to replace the speedometer sensor..it control the transmission shifter by sending the signal to the pcm and the pcm to transmission shift solenoid..that why it don't shift right
Apr 21, 2010 | 1999 Mercury Cougar
I own a 99 couger and my radio wont work,if checked the fuse and its fine. the radio just wont turn on at all
now it really matters on what kind of radio it is but most have a built in fuse try lookin in to if yours does also check the hot wire and the negative wire leading into your radio this should work :)
Mar 24, 2010 | 1999 Mercury Cougar
Battery light stays on 2000 mercury cougar with v6 engine battery light stays on
Your alternator isn't putting 14 volts out to the battery. Check the stator wire on the alternator and the 3 wire plug make sure there is no gap on any of the alternator connectors and they are on VERY firm!
Hook up a multimeter inside your car and watch the battery voltage! if under 14volt you got an alternator problem!
Jan 08, 2010 | 2000 Mercury Cougar
2002 cougar. Turn key nothing not a sound.
sound like alternator quit charging the battery.check battery voltage.it should be 12.5 volts.if not charge the battery.remove and have alternator tested at auto zone or advance auto parts.dont forget to turn off radio when disconnect negative battery cable.
Aug 09, 2009 | 2002 Mercury Cougar
99 mercury couger-all headlights not working
check the fuses and relay that control the headlights
Jul 13, 2009 | 2000 Mercury Cougar
Where is the water pump located on a 99 couger.
not familiar with this vehicle, but waterpumps are not usually tied into to the timing, but can be mounted behind it
Feb 16, 2009 | 1999 Mercury Cougar
Battary
you have to find out what is drawning on the battery to keep killing it I would check out the alternator and drive belt make sure the battery is fully charged and does not have a weak cell
Jan 25, 2009 | 1999 Mercury Cougar
174 people viewed this question
 Grubhead
Grubhead
