Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd63s not draining
My washing machine is not draining so that why is not spinning i suspect that the draining system is block where can i find the draining system its normally at the front but nothing in there can you please tell me.
  • Anonymous Apr 02, 2008
    water draining completely after the wash
  • Anonymous Jan 13, 2009
    My Hotpoint WD63 began by not always emptying the drum on a cycle, it has become progressively worse until it reached a point where it no longer drains at all.
    Having initially checked for blockages in the waste pipe it became apparent that the blockage was further along.
    I removed the back panel to gain access to the drum's outlet and filter, though I do not suggest doing this without first bailing out the drum, and having something underneath as I grossly underestimated the volume of water that was going to pour out!!
    Once removed I removed the filter (having unclipped the latched clip) I thoroughly cleaned the remenants of bra, hair clips, fabric and coins from it until all the holes were unblocked.
    I then re-attached the filter to the pipe (important to ensure clip is very tight otherwise it will leak) and re-attached the pipe to the drum outlet (don't foget the washer or again it will leak).
    I then ran the machine through a quick cycle. I can feel the pump try and kick in but not all the water is being pulled through. I am beginning to wonder if the sensor/mechanism that controls the pump is faulty since some water is removed.
    Any assistance would be appreciated
    Thanks
    Hope the pictures help, otherwise they are testimoney to failure ;)
  • 57 Answers
THE DRAINING SYSTEM IN THESE MACHINES IS UNDERNEAT YOU HAVE TO UNPLUG THE MAINS TURN THE RED AND BLUE VALVES OFF THEN YOU GET A BASIN AND PUT IT ON TOP OF THE MACHINE TAKE OUT THE DRAIN HOSE AND PUT IT IN THE BASIN SLOWLY BRING THE TWO DOWN TO THE FLOOR AND MAKE SURE THAT ALL THE WATER IS GONE THEN PUT THE MACHINE ON ITS SIDE YOU WILL THEN SEE A LARGE HOSE AT CENTRE OF DRUM UNDO THE CIRLCLIP AND PULL OUT THE PLASTIC FILTER AND CLEAN IT OUT PUT BACK IN REVERSE ORDER OF WHICH I HAVE WRITTEN.
Posted on Jul 16, 2008
SOURCE:
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Smeg washer dryer not draining
Sounds tricky you may want to try this site, there's loads of help, advice and videos to help diagnose faults.
Give them a try. Hope you get this sorted. How to diagnose draining problems
Jan 31, 2014 | Smeg WDI12 Front Load Washer / Dryer
Whirlpool washer comes to abrubt stop after spin cycle
Check if the drain pump is activated, check the voltage on the drain pump at the end of the spin cycle and if absent then the program controller unit is the suspect. If there is voltage then the drain pump must be removed and checked, it can be blocked or damaged.
Sep 09, 2011 | Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Machine runs wash cycle but fails to drain and spin. When door unlocks I remove and replace wet washing then switch on rinse and spin cycle. This seems to work but is no long term answer.
Hi, The washer will fail to spin if there is too much water in the machine, check the filter on the machine is not clogged or blocked if it's not then the pump could be suspect, normally you can hear it running on the spin cycle. it could also be the motor brushes are worn.
if its none of the above I would suggest that it maybe the pressure switch or pressure switch tube blocked other than that the last resort is the programmer or motor control panel.
Hope this helps.
Feb 09, 2011 | Hotpoint Aquarius WD63 Front Load...
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Will not drain. it does'nt look like its spinning very fast.
The washing machine not draining water.This problem is related to few possibilities. 1) The drain pump is got loose to the drain hose. check the connection from drain hose to drain pump. 2) The drain is blocked by any thing.Like cloth or any thing like metallic nails or coils etc etc. 3) The drain hose is got blocked./The drain hose is not letting the water to enter the drain pump. In most of the cases the drain pump has to be removed and checked for any kind of blockages.Also if the machine not draining can effect the spin cycle.But other possibilities for no spin or slow spin are faulty or broken motor coupler or weak spin motor.The motor coupler and motor both can be possible,if the drain pump and drain hose both checked ok.This will clear the fault. ----------- Keep updated with any more queries.Thanks,.
Oct 14, 2010 | Washing Machines
My LG front loading washing machine gets halfway through its cycle then sits there humming. I have checked the pump it's not blocked or jammed. I can drain the machine & run a spin cycle all correctly...
Seems to me the board may have an issue at the thyristor or relay. Unfortunately, with LG,the board is covered with appoxy so as not repairable. The motor is usually very durable and very seldom go faulty. When selecting the spin cycle, a second triac activates that part to spin the motor. (again ,suspect the board.)
Aug 15, 2010 | LG WD-16115FD Front Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
293 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
