Question about Sony KP-53V80 53" Rear Projection Television
Sony kp-53v80 i push the power button and it acts like it is going too come on and goes right back off no sound or vedio i pulled the 5 volt jumper wire out of the socket and the sound comes on i changed the horiz.output chip and it did the same thing.mike be voltage regulator.
  • mancinia Jun 22, 2008
    I have the same problem, the tv power goes on but I have no picture or sound..................AM
  • 55 Answers
Check the 470UF Tank capacitor in the Switching Power Supply.Sometimes when heated,it gives trouble.
Posted on Apr 01, 2008
SOURCE:
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony big screen tv model# kp-53v80
It can be just an adjustment of your screen control. There is a "sweet spot" on the control where it allows the picture to come through. This is a common problem with sets that are getting old. If there is a problem with the high voltage from the color tubes then it will shut down the video until the problem is gone and it is safe again to show the picture. This is known as going into a shutdown procedure to protect the set. A technician will be needed to fix your problem since it will require proper troubleshooting and knowledge of high voltage system and safety procedures.
Sep 22, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Sounds like one of the tubes is shorting out causing the set to go into a shutdown status so it won't cause any major damage to the set or house.
Sep 06, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Mar 25, 2008 | Sony KP-53V80 53" Rear Projection...
    Sony tv model #kp-53v80
    you have most likely a shorted hori out out NTE2324 and look around hori there is a 1200pf 2k volt cap that goes bad.I have fixed alot of sonys with this problem.
    Jan 28, 2008 | Sony KP-53V80 53" Rear Projection...
    Sony KP-53V80 53" Rear Projection Television Logo
    54 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
