Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5102WLMi
Sometimes like now when I am trying to turn my laptop on the power button lights green but the computer won't turn on. I have tried unplugging it but nothing. i have tried starting it using just the battery but nothing. i opened the cd drive and closed it i hear it running but the computer won't start. can't figure this out. i tried even using a different plug and that did not work either.
    Genius:
  • 1,226 Answers
Hello.
First try remove the battery to reset all the stting. sometime it causes hang -up.
try also switch on the laptop using only the power cord from the wall outlet.
if not solve then,
try also refix the memory card , remove, clean it and insert it back.
if this not solve the problems tell me what happen, do not rate me until i solve the the issue.
melnavz
Posted on Apr 01, 2008
    Sergeant:
    Champion:
  • 244 Answers
Try to reseat memory.
If you have 2 memory,
try to use 1 memory and if it don't work, try to move it to different slot.
If it still don't work, i suspect your motherboard have problem.
SOURCE:
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
Green light on. computer wont turn on
Unfortunately, if the light is on, but the computer won't power on, it means one of two things. Either the power cord is broken in some way and no long sufficient to power the computer, OR the motherboard is dead. You can try to purchase a universal cable from Best Buy for instance, and then return it if it doesn't solve your problem. A motherboard repair would be best done through Acer themselves, although, it can cost over $300.
Aug 23, 2011 | Acer Aspire 5735 Notebook
Turns the power button on and the power light keeps blinking in and out and the computer won;t come on
I would look into testing the laptop by taking out the battery and plugging in solely the charger, and try turning it on. If it doesn't work, it sounds like it can probably be an issue with the Motherboard or the RAM.
Is the blinking light an amber or green color? If amber, then it might be a RAM issue. If green, the power would be on, but the monitor might not be active/working.
Apr 03, 2011 | Acer Aspire AS7741-7870 Notebook PC and...
My Acer 5102WLMI Laptop will not start completely without giving me error messages and then freezing, what do I need to do to fix this problem?
It appeats that some of the Operating System files are missing. I advise you to perform a full system restore so that it will be back to factory settings. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.b.R
Aug 18, 2010 | Acer Aspire 5102WLMi PC Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5102WLMI speakers
Make sure you have the correct headphones for your computer stereo not mono the inner connector on the computer socket and the headset connector must align exactly if the speakrs still play while the headset is plugged in you have the wrong type of headphones connected try logitech brand Headphones designed for computer listening
do you not have plug specifically designed for a headset on your computer?
Jan 13, 2008 | Acer Aspire 5102WLMi Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
78 people viewed this question
Ekse
Alun Cox
