Question about Canon PowerShot SD950 IS Digital Camera
Power source i need to charge it but i lost the charge where would i find one
  • 477 Answers
Radio shack has a universal
Posted on May 15, 2008
  • Mike Johnson
    Mike Johnson May 20, 2008
    why do that when you can get one off ebay for around 20
  • 2,039 Answers
Go here. The charger you need is the CB-2LX, and the price from Canon's online store is $50.
Posted on Apr 20, 2008
HOOKING UP THESCOSCHE 500K MICRO FARAD CAPACITOR. I LOST THE HOOK UP DIAGRAM AND DON'T WANT TO HOOK IT UP WRONG
Connect ground wire to ground. Connect positive wire to the same positive wire as the amp is. If you lost the charging resistor then connect the wire to the cap first then connect to the power source. This will keep it from sparking and damaging the plating on the connector.
Jul 31, 2016 | Heating & Cooling
Harley ignition problem
The alternator is bad. IT is not charging the battery. When the voltage drops on the battery it dies, When you jump it the bike starts because power is coming from some other source but when you disconnect that source it dies because the battery has not charged back up.
Sep 01, 2013 | Motorcycles
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
Apr 20, 2013 | Xantrex Technology Duracell Powersource...
Can I charge my Fujifilm Finepix XP10 with the USB cord?
No, you must charge the battery outside the camera using a charger. One source for a third-party charger is here.
Jun 24, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
I have a garmin gps nuvi 255w and I wanted to register it, but a massage keeps on poping up saying external power lost shuting in 29 seconds.What should I do?
Try to charge your nuvi properly and full, or for at least 2hours before registering it. If the source of power connected to your nuvi is not strong enough, the nuvi might go off during an operation. Secure that the battery is well charged, then the source supplying the power is good enough to supply your nuvi with power before starting an operation.
Hope this helps.
Dec 24, 2010 | Garmin nuvi 780 GPS
How to charge battery, is there a charger that we have lost or does it charge while on player & plugged in
The player charges, with or without playing a disc on it,
First step to charging your battery is having it plugged without playing it for a while.
There should be a light that comes on when you plug it to a power source.
When it is full, there also is another light that comes on to signify it is full.
You can also charge it while playing a DVD on it.
But if it does not charge when you plug it without playing a Disc on it, then there is a problem that need to be fixed on it.
test if the battery is charging.
  1. plug the player to a power source for some time,
  2. wait for some time for it to have charged very well,
  3. unplug it from the power source,
  4. test a disc on it to see if it will play.
if it does not play, then it means there is a problem.
which could be that the battery may be faulty.
All you have to do is to replace the battery and it will work perfectly fine again.
take care
Jun 18, 2010 | Polaroid PDM-0723 Portable DVD Player
I lost the instructions and it continually says low battery
I had the same problem and discovered from the instructions it will only charge the battery if in the "off" position on the side ie it is not charging if it is plugged in to a power source and being used.
Jan 24, 2009 | Philips PET702 Portable DVD Player
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Phoenix digital 1.5 farad capacitor installation
First off Charging the capacitor can put you holding a high power voltage source. This can be very dangerous. It is enough to kill you. I suggest for safety go ahead and mount the capacitor in its location. The easy way to charge a capacitor is using a 12 volt Battery Charger. Hook the charger up to the capacitor just like it is a battery. + to + and - to - ... Charge the capacitor until the charger meter falls to near zero amps or indictates full charge. No need to use a light bulb or anything. The Charger comes with it own limiting circuitry. I will be posting the wiring instruction shortly.
Dec 02, 2007 | Car Audio & Video
Canon PowerShot SD950 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
