Question about Hitachi 50V720 Television
50v720 Color Issue / Reply w additional details
Dan - the overall picture quality is fine - its just green... period. Everything has a green hue. No adjusting of color/tint/contrast helps.
I am sure it is very dusty, but have no idea which screws to remove for easy access - is there a service bulletin on this procedure?
  • 4,234 Answers
I'll check on your specific model, but this problem is usually caused by degradation of the LCD light engine. Hopefully we can work around it for the short term. I'll update this with the model specific info in a day or so (I'm traveling at the moment).
Dan
Posted on Apr 01, 2008
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Color issue
download this manual
http://merchant.satisfusion.com/sf/library/manuals/owners/50V720.pdf
see page 59,60,61,62. The problem can be the lamp
After extended use, if the TV picture turns dark, the color looks unusual or LAMP INDICATOR light turns on, then it
is time to replace the lamp with a new lamp.
Mar 21, 2008 | Hitachi 50V720 Television
Color needs reseting in the box it keep showing green red & blue needs to reconfigurating
If the picture looks like a 3-D one, the problem is with the convergence circuit. Please confirm the model number to be D52W20. I will supply additional details based upon the model.
Thanks,
Dan
Jun 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color has an overall blue hue to it
Please check all the pins at both ends of the VGA cable, also try it on another PC.
http://s807.photobucket.com/home/budm/allalbums
May 13, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Why is the picture getting a green hue on and off instead of the normal color?
This may be caused because your color and other settings may not be set according to your needs. Try resetting the color, brightness and contrast with the help of your remote. If your set is new and within warranty period you can have a free checkup or replacement from the company.
Apr 07, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Pictures have a purple hue to them Cyber-Shot DSC-P52
I suspect that the color is fine in the screen, if that’s true I would check the “White Balance.” This control is use to compensate for different light sources. The electronics will respond different for sunny or cloudy days and for incandescent or fluorescent lamps. I suspect that it was taken out of AUTO mode. I find that AUTO works well for most people in most situations.
Select photo or movie mode press menu, select WB, select AUTO.
Dec 04, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Hitachi 50V720 Television Logo
212 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
