Question about Linksys Wireless-G WRT54G Router
Router have high speed internet service road runner with phone service how do I download wrt54g router wireless
    Genius:
  • 1,027 Answers
I usually don't use the software, I use the default IP address of the router to log into the router and set it up. Manual
to enter the routers utility,plug the pc/laptop into the router with the cat 5E cable, open the browser, type in the routers address,
192.168.1.1 User is blank password is Admin.
software.from this link, choose which wrt54g you have version 1-7
Posted on Apr 01, 2008
Service Hook-ups...
1- in order of what connects to what
1- linksys connects to road runner modem. Should be a network connection on the back of the router that says uplink. This connects to the road runner`s wired port on the back of the unit.
Vonage phone will/should connect through the wireless section an in your personal wifi connection when you get the router wireless setup. Name your wireless something that other people are not using and then tell vonage phone to connect to that network.
Hope this helps
Feb 16, 2014 | Linksys E3000 Wireless Router
I cannot install my router
The WRT54G give a high-speed Internet connection, via Ethernet, with up to four computers.Setting up the router consists of some steps.Read more
Aug 23, 2012 | Linksys Wireless-G WRT54G Router
Need help, router will not connect. The internet service road runner is working when I plug directly in computer but through the router it won't activate. This router has been working for over a year now...
Try unplugging the power from Road Runner modem and disconnect the computer or router. Then only plug in the power to the router and plug in the power to the modem.
If this does not work, try resetting the modem's config to factory defaults by sticking a paperclip end into the reset button hole in the back while powering it up. hold the buttin in for atleast 15 seconds while the router restarts. then retry the first suggestion.
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
Installing Westell modum to time warner high speed
Please view my How-To on how to program your Linksys WRT54G router. You can view it at this link:
http://www.fixya.com/support/r3995607-setting_up_or_resetting_linksys_wrt54g
Good Luck,
NOLA Tech
Jan 22, 2010 | Linksys Wireless-G WRT54G Router
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Linksysy asks for a network key (Wep key or WPA key)
1. Using a computer that is wired to the router, access the router's setup page by typing 192.168.1.1 on the address field of your browser.
2. By default there is no username and password is admin.
3. Once you're in the setup page, click wireless then there is a sub tab there called wireless security.
4. You will find there the wireless key that is enabled in your router.
Nov 08, 2008 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Ipod touch and road runner
try to reset the Network from ipod
choose Settings > General > Reset > Reset Network Settings.
Damn sure it fix trust me
May 04, 2008 | Apple iPod touch
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Not working on my 2nd computer
I am going to assume Vista is the first OS and both machines are windows computers and you are accessing the cable service through a DI-524 wireless router. There are many issues that can relate to your problem. First does your cable provider require you to logon to access the internet. If so, try using each computer individually (with the other one logged off and shutdown) with the existing wireless connection. If this works both machines are configured correctly for the router and the issue appears to be dealing with the logon possibly having it performed by the router if possible. Second if that does not work -- on each machine bring up a command prompt window (Start > All Programs > Accessories > Command Prompt) and type ipconfig and press enter. There may be multiple local area connections but look for one with a 192.168.?.? address on each machine. The first question mark should be the same on both machines and the second different. If this works both machines have connected to the router and we are seeking another issue. If this is not true one machine has a configuration problem and cannot access the wireless router (probably the Windows ZP computer from you description). We will need to diagnose further once you answer the above questions.
Dec 05, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
