Question about Canon XL2 Mini DV Digital Camcorder
How to hook wireless mic to canon xl2
I'm trying to hook a WM-Pro wireless transmitter brand name Azden to my canon xl2 and i'm not getting any sound.
  • Anonymous May 11, 2010
    What are you using to attach the receiver to the camera? where are you plugging it in?
Plug it into Audio 1 ports, switch to audio, not mic on the physical camera, then check that you have selected stereo 12 bit, 1,2 from the record audio menu.
Also note you have to push the button next to the audio meter to monitor different sources.
Posted on Nov 11, 2008
SOURCE:
How do I stop the constant hum coming from my Azden SGM-1X Professional Microphone?
If the hum is from line pickup, it should be 60hz or 120hz. If you are connecting to a line powered device, you might want to try a direct or isolation box. There's a ton of them like these
Passive Direct Boxes
And see if orienting the mic at a different angle. Try turning off fluorescent lights. Isolate ie as much as possible.
Jan 01, 2015 | Azden SGM-1X Shotgun Microphone
Can i hook up my gmw-61 to my stereo recevier
if there is a microphone jack or similar item with your wireless mics you should be able to plug it in the mic jack on your stereo and it should recognize it
Mar 11, 2014 | Gem Sound GMW61 Dual Wireless Microphone...
MY VIDOE CAMCORDER WILL NOT RECORD SOUND WHEN I ATTACH A MIC
You need to connect your mic to an amplifier first and then to camera. Orherwise mic has not enouth power output. Zoom h4n might work but its expansive. Or u can buy wm-v1, wireless mic, it'll work just fine. Or buy mic with power already built in, like Rode VideoMic.
Apr 12, 2012 | Canon VIXIA HF R20 Camcorder
Have an Aiptek HD 12 1080p with Azden wireless mic system. no sound with wireless mic, but sound works on camcorder without the wireless.
you need to use a mono-to-stereo cable, the azden is a mono output mic by the aiptek is a stereo input and you are shorting out the phantom power with a mono plug in a stereo jack.
- DL
Sep 06, 2011 | Aiptek Cameras
I have Canon XL2. It suddenly stopped recording sound. I replaced front mic, tried different mics from the rear connections - neither case, i can not get it record a sound. Video is fine. Any help would...
This could be a fault in the audio processor board or possibly a defective audio head. Either of these can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 04, 2011 | Canon XL2 Mini DV Digital Camcorder
How to make Shure wireless mic work with Azden 305
Sorry, that is not possible. Different manufacturers use different companding, noise reduction, and squelch schemes. Thus, even if they are on the same frequency, you might not get any audio or the audio might sound quite funny.
May 06, 2010 | Shure ULX1 Body-Pack Transmitter...
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
Canon XL2 Mini DV Digital Camcorder Logo
408 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
