Question about Zojirushi NHS-10 6-Cup Rice Cooker
Rice cooker spits rice juice all over counter
When we cook brown rice, even though we have rinsed it repeatedly, hot rice juice spits from the hole in the cover all over the counter. We have to move it away from everything and put a towel down to deal with the mess. We've tried putting a 1 oz. childs plastic medicine dispensing cup with holes cut in it over the hole in the lid, as well as a paper towel or cloth napkin, but all of these attempted solutions result in hot rice juice spitting out from the opposite side of the lid, making a mess on the other side of the cooker. What's up? We thought we were upgrading from a $20 black and decker steamer, but we've been very disapointed so far.
I had the same problem when I cooked brown rice in my rice cooker! I found that adding a tablespoon of butter on top of the cooking rice solves the problem. (A friend told me it works when cooking beans in a pot, so I figured it would help with rice too, and it did!)
Posted on Nov 05, 2010
I think I have this cooker. It has strong heat. It cooks white rice fast but with brown rice it can singe the bottom brown. Mostly because it is a hot cooker. So I just make sure I turn it off a little early and just let the rice steam cook at the end. Hope this give you some help. Ps. Make sure your lid has the little air hole for air to escape. Mine does. Hopefully yours does. If it doesnt then that is the problem. Too much pressure from boiling with no air escape. I would suggest if so. Let the cover slightly leave a slight air escape. Robya
Posted on Apr 09, 2008
Rice cooker fuses rice together...have tried several rinses before cooking, but doesn't help. I have to get rice out immediately after cooking, and still find some brown clumps!
try different ratios of water to rice generally 1.25 to 1 for whie and 1.75 to 1 for brown vary until you find the right ration for your area
Jan 15, 2018 | Kitchen Appliances - Others
I need insturctions on using the avon rice cooker for microwave
1. Before cooking, optionally rinse or soak the rice. This is necessary for some types of rice (especially brown rice, which is much harder than white rice), but it improves the flavor and texture of most types. To rinse, put the desired amount of dry rice in a container and fill it up with cold water. Use clean hands to sift the rice in the water. Drain and repeat. To soak, put the desired amount of dry rice in a container and fill it up with cold water. Let stand for 30 minutes, and then drain.
2.Mix rice and water in a microwave-safe container. A good place to start is two parts water for every part of rice (e.g., 2 cups rice to 4 cups water). You can adjust the ratio through experimentation, depending on how dry or moist you prefer your rice, the power of your microwave and the size/shape of the container.
3.Enhance the rice with flavor. Add salt, vegetable oil, olive oil or butter before cooking. A teaspoon of salt/vegetable oil or 1/2 tablespoon of butter should do the trick for each cup of rice.
4. Stir the rice mixture slowly with a wooden spoon. Combine the ingredients thoroughly. This is especially important if you have added other ingredients for flavoring.
5.Cover the rice. Place in the microwave and set the timer. Here are some suggested guidelines for a 700 watt microwave and white rice:
  • 1/2 cup rice, 9 minutes
  • 3/4 cup rice, 12 minutes
  • 1 cup rice, 16 minutes
  • 1 1/4 cups rice, 20 minutes
  • 1 1/2 cups rice, 23 minutes6
6. For brown rice, start with three cups of boiling water per cup of rice and cook it for 25 minutes
7. Let the rice sit in the microwave for five minutes after it turns off. Don't open the door. The steam will complete the cooking process. You might observe that the rice grains start to orient themselves vertically, like they're "saluting".
8. Fluff the rice with a fork and serve.
hop you enjoy it
Aug 15, 2014 | Kitchen Appliances - Others
How long dose brown rice take to cook
  1. 1Rinse the rice under cool water. Place the brown rice in a fine mesh strainer and quickly rinse it under cold running water for about 30 seconds.
    • Make sure that the strainer is made from very fine mesh. If the gaps between the wires are too large, you could end up losing an unfortunate amount of rice as you rinse it.
    • Note that you may not always need to rinse the rice, and this is somewhat of an outdated practice. Rinsing is a cleaning process and is a necessary step if you suspect that the rice has been imported or handled roughly in bulk storage. If the rice is a fortified, domestic product, however, you probably will not need to worry about rinsing it.[1]
  2. 2Soak the rice for 45 minutes in hot water.[2] Transfer the brown rice to your rice cooker and add 3 cups of water to the basin, as well.[3] Let it soak and soften for at least 45 minutes.
    • You can soak the rice up to 3 hours, if desired, but 45 minutes will often be enough.
    • If you prefer a more flavorful rice, you could substitute some or all of the water with chicken broth or vegetable broth. Substitute the broth in equal amounts for the water.
    • Soaking is beneficial because it reduces the stickiness of the rice. It also helps the rice expand into long, thin grains.
  3. 3Add salt, if desired. Sprinkle the soaked rice with salt, if desired, to draw out more flavor from the rice as it cooks.
    • Give the contents of the rice cooker a quick stir with a wooden mixing spoon to distribute the salt more evenly.
  4. 4Turn the rice cooker on and set the timer. If your rice cooker has a brown rice setting, use that. If it only has a timer, set the timer for 30 minutes.
    • The rice cooker must remain covered for the duration of the cooking process.
    • Check the rice after the first 30 minutes. If the grains still seem tough and the content of the basin are still somewhat soupy, cover and set the timer for another 10 minutes.
    • Understand that each rice cooker varies by make and model. In order to cook the rice as best as possible, you need to read the instructions that come with your rice cooker and set the timer and other settings according to what you read there.
  5. 5Let the rice stand. After the timer goes off, let the rice stand for another 5 to 10 minutes so that it absorbs any remaining water in the basin.[4]
    • Leave the cover on as the rice continues to sit.
  6. 6Add butter and/or soy sauce, if desired. If you want to flavor the cooked rice, you could add about 2 Tbsp (30 ml) of butter or margarine or 1 Tbsp (15 ml) of soy sauce. Stir well to coat the rice evenly.
    • You could also wait until after you place the rice in serving dishes before seasoning it. That way, everyone can season the rice according to his or her own tastes.
  7. 7Serve hot. Transfer the rice to serving dishes or set it aside for use in other recipes that call for cooked brown rice.
Aug 03, 2014 | Aroma Kitchen Appliances - Others
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
Info needed on rice cooker Bravett model MC665H, how rice can go into pot, what type of rice, and how long to cook
A cup of rice is equivalent to two person, depends how a person consumes the rice.
First wash the rice by rinsing it two times( using the pot itself ) with fresh water, add water till it cover the whole rice, amount of water should not exceed the level of your first line mid finger. After that put it in your rice cooker and switch it on. Rice cooker cooks it automatically.
White rice does not need extra time to cook.
Brown or any colored rice should be left or soaked for 10 to 15 minutes before cooking it ( because it is a bit hard ).
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | Bravetti Kitchen Appliances - Others
How do I cook brown rice in the rice cooker?
I tried it once and it wasn't easy. It appears that the automatic rice makers are calibrated for whit rice. Anyway, I had to add about twice as much water as white rice takes and restarted the cooker once or twice until it was done. It was a failure and I never attempted to cook brown rice in it again.
There may be rice cookers that have a setting and instructions for brown rice, but I've never seen one.
Good luck.
Sep 03, 2009 | Panasonic SR-G18FG 10-Cup Rice Cooker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
How do I use the salton ra10 rice cooker.
It came with a small plastic measuring cup. The ratio for that is 1 cup rice to 1 cup water (using the measuring cup for both items). Measure out your rice first, BUT for best results you need to rinse your rice several times (I do three times or until the water is fairly clear). Place rinsed rice in cooker and add equal amout of water . You can also add in your butter and salt at this time if you wish. put lid on cooker,plug it in and push the little lever down (it'll click). It will cook for about 20 minutes and the lever will pop up on its own. Don't do anything yet! you need to wait about 10-15 minutes more, or at least until the steam stops before you open the lid. The rice should be cooked perfectly.
There will (with this model) be a light brown crust on the bottom of the pan, butthe instruction manual said that it was a normal occurance (but it is a buggar to get that off-soaking for a couple hours helps).
I really like using rice cookers because they do a great job in cooking the rice. I hope this clarified how to use this model.
Jul 23, 2008 | Salton RA10 10-Cup Rice Cooker
Rice is sticky and clumpy after cooking
Sounds like it's working perfectly for an Asian family. :-) Our rice cooker is a different design (made for Americans) and we can reduce the stickiness by adding more water than called for and rinsing the rice before cooking. Good luck!
Jun 27, 2008 | Zojirushi NS-PC10 5-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Zojirushi NHS-10 6-Cup Rice Cooker Logo
919 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
