Question about IBM ThinkPad T21 Notebook
LCD screen My laptop screen is completely white or black when I turn it on, I can not see a thing. Sometimes I turn it on and it is fine, then it randomly does a spiral/morph thing to a white screen. What is it and what do I do?
  • IBM Master
  • 13,433 Answers
Hey, most likely
1. The screen is damaged
2. Vga adapter failure.
In both cases the laptops parts might need to be replaced.
Possibly the whole motherboard if the vga chipset has failed.
Might cost alot and a better choice might be to buy another laptop.
But I recommend you contact ibm, your dealer or a local professional for more assistance on the problem
if you need anything else let me know. Good luck.
Posted on Apr 02, 2008
    Genius:
  • 2,785 Answers
Please check it out with qualified professional
How can I check my dell d820 screen? It stopped working
Hi, first:
try to connect to a VGA Monitor (it has DB15 Connectors(bing or google it) and usually in blue or black colors) and press and hold windows key then press P on your laptop keyboard or (peripheral PC keyboards) tap these shortcut for 2 or 3 times and see what happened, if you see any changes on monitor or see your screen on the VGA monitor your Graphic card is fine so go to the next step if not
maybe you have chipset problem or bios (UEFI) problem so go to the certified Repair shop,
next step:
some laptops have a shortcut key to turn your LCD off in expanding screen mode for decrease power consumption. try press (fn + keyboard key that sometimes has a rectangular icon with x icon on top of it) if you try but nothing changes or see white screen or glitch
screen pixels then 2 possible things happened,1- your LCD flat cable or 2- may be your Screen LCD damaged in this case go to certified repair shop center
best regards
Jun 16, 2014 | Dell Latitude D820 Notebook
Compaq Presario CQ62-215DX has a white screen
Need to check the connection of the LCD to the motherboard.
http://h10032.www1.hp.com/ctg/Manual/c02641795.pdf
Start on page 70 and follow exact instructions
Dec 08, 2012 | Compaq Presario CQ62-215DX Laptop
Why asus screen turns into white sometimes?
you have a bad connection in the lcd cables,either a cracked ribbon from regular usage or the connection is loose. the white screen is lit but no data is visible, black screen, ffl tube or inverter is bad. check connections first, always check the simple things first.
Jan 22, 2011 | ASUS Eee 4G Notebook
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
Display driver stopped responding and successfully recovered
try checking for updated drivers for your hd 5730. i have seen this in desktops with both ati and nvidia gpus.
Jun 21, 2010 | Alienware PC Systems Alienware m15x Gaming...
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Feb 01, 2010 | Computers & Internet
Problem with Acer Aspire 5315 Laptop screen turning white
I work for an Acer service centre and your laptop shuld be under warranty. I'd suggest to have it checked by a service centre close to you as it is a hardware problem, possibly with the LCD.
Feb 24, 2009 | Acer Aspire 5315-2153 Notebook
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
My computer turns on sometimes the quickly goes blank. Other times, the On light comes on but the screen stays black and nothing seems to be moving inside.
try to desconnect or unplug your hard drive, if you see a black screen with a bunch of white letters, you hard drive is crashed, if not try to conect a second monitor (external) tru you vga connector, if work fine you have a lcd problem===>>>reemplace asap.
Dec 02, 2008 | Compaq Presario 700 470024-192 Notebook
IBM ThinkPad T21 Notebook Logo
119 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
