Question about AOpen AX45-V (91.88I10.004) Motherboard
Cpu removal I have a AOpen AX45-V Motherboard Problem, my cpu is hard to remove, andy suggestions
  • Devocap
    Devocap May 11, 2010
    Hey there mmatt58581, have you managed to remove the heatsink and fan?
  • 807 Answers
If you have loosened the heatsink and fan but cant pull it off, you have to carefully twist it left and right to free the heatsink compound. If you just try to pull it off you will pull the processor from it's socket.
Posted on Apr 01, 2008
  • 236 Answers
If you are removing the cpu itself, you must first release it by pushing the metal lever over a bit, then lifting it up..
If you are removing the heatsink and fan, you must first release the 4 clips on either corner of the heatsink. (pull back a little on then, the pull up, careful not to damage the components).
6ya staff
SOURCE:
Hard drive doesnot spinup when ide cable plugged but spins up without it plugged in. Are there any jumpers that need to be set?
make sure you ide cable is plugged in correctly and set jumpers to master the diagram is on the hard drive.
Jan 29, 2011 | AOpen AX45-V (91.88I10.004) Motherboard
Do you know what the max memory supported on the AOpen AX45-4D motherboard? Thanks!
From what I can remember the motherboard supports 2GB of ram (1x1GB in each slot).
Regards.
Jan 07, 2011 | AOpen AX45-4D Max Motherboard
I have an ax45-v that wont boot past ram check..ram check says ok but than comp freezes
Change ram bank, clean your ram, try to load windows by pressing F8 key and then in Safe Mode.
Regards;
Hassan
Jul 15, 2009 | AOpen AX45-V (91.88I10.004) Motherboard
Underclocked with my new processer
Check the motherboard for jumper settings to change clock speed etc as usually if its not in BIOS its on the M/board
Aug 23, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Beeps
You have an Awared Bios. The link below details what your bios beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
I suggest you remove your memory & re-seat it & do the same for your video card to be on the safe side.
This next link list some basic's about your board.
http://www.pcstats.com/articleview.cfm?articleID=1008
Good Luck.
Mar 14, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Help pc problems???
CHANGE THE POWER SUPPLAY.. BUT FIRTH..
1-UNPLUG HD AND TEST WITH FLOPPY OR CD BOOT DISK
2-UNPLUG YOUR MEDIA ROOM LIKE CD OR DVD AND TEST ONLY WITH FLOPPY BOOT DISK
3-UNPLUG VIDEO CARD AND ALL CARD ON YOUR MOTHERBOARD.. TEST ONLY WITH THE FLOPPY DISK AND ONBOARD VGA.. OR GOOD TESTED VGA CARD.
EXCUSE MY BAD ENGLISH.
CO3OV
CUBA
[email protected]
Oct 14, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
No Display on screen.
If available, try using a different video card to see if it will POST. The only other thing I can think it might be is that the processor isn't seated correctly, or that it is seated correctly but you have too little, or too much thermal compound on the CPU.
Sep 15, 2006 | AOpen AX45-V (91.88I10.004) Motherboard
AOpen AX45-V (91.88I10.004) Motherboard Logo
76 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
