BLINKING LED I HAVE A SONY KV25ST12,, The first problem i encounter is that it has a 4 blinking LED,, other site said that it is a problem on vertical deflection.. when i tried to replace the vertical deflection IC... it given me now a 3 blinking led ... this said it was cause by over voltage protection.... the question i ask for is that which part of the board is over voltage protection located? .. is it a parts or circuit?... is there any parts that should i replace and if it is, what part was that? i would gladly appreciate any help on this problem....i been doing this on a month but nothing happpen...
    Champion:
  • 213 Answers
4 blink v stop you need to go in for fix.
Posted on Apr 01, 2008
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
My sony crt tv model no kv-tg21l70 have 4 blink i replace the vertical ic but it has no change so what shall i do?
By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 05, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
Sony crt tv (KV-BZ14M70) led blinking four times in stand by mode, so it means?
Hi Ullah,
LED blinks four times on KV series means that the Vertical deflection circuitry encountered a problem. You can repair it yourself if you have knowledge in electronics, knowledgeable in soldering and desoldering of parts on the board.
jimvincentvillanueva@yahoo.com
Jun 14, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
KV-34hs420 LED Blinks 4 times
Apr 28, 2012 | Sony KV-36XBR400 36" TV
Sony KV-20Fs100. Same problen as #4620488. TV
4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button doesn't do anything, remote doesn't work, 4 blinking lights. Sony kv 36fs120.
you have power issue. short the prongs for a minute. then remove the short wire. then test. if not succesful go to your nearest service center.
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TY,found scematics,ordered parts,mine only blinks 4 times though!Is this a different problem,am i wasting my time with the diodes?.Can hear aclick like a relay,when I try to turn on,standby blinks 4...
According to the self diagnostic system 4 thimes LED blinking,
The fault is in vertical section, Vertical deflection is stopped, 15V not supplied (D Board), IC 5101 could be faulty(D Board).
Therefore check the above mention area it will help you.
Thanks for using fixya.
Jun 28, 2009 | Sony KP-57WS520 57" Rear Projection...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
