Question about Bosch Axxis WFL 2060 Front Load Washer
New Bosch water not draining
I just got a new Bosch Axxis 2060 and I've had it for 5 months and I'm just starting to notice that when I open the door it smells like mildew. I've seen a little standing water inside the rubber thing around the outside, how do I clean this? My clothes don't stink yet, but the smell is only getting worse, so I'm sure it'll start soon.
  • basecamp1301 Aug 10, 2008
    I noticed it when mine was a few months old, too, and was very disappointed. I could not find the source, either, but noticed that when I kept the rubber thingy wiped out and left the door open, it wasn't as bad. (not a good feature since it was in my kitchen.)  I accepted that the problem was just an annoyance.
    It is two years later, and I now have a housefull of clean clothes that I can't wear because they smell too strongly of mildew to wear.
    I decided today to get to the bottom of it, because my son told me he pulled the rubber thingy back and there was a strip about 12" long by 3" wide of furry black mildew there.  I scrubbed whatever I could of that out, and then decided that since I couldn't get it really clean I would like a new rubber thingy.  So I tried to see how it was attached and discovered another forest of mildew behind the rubber thingy.   I would try to get your money back if you can, I can't imagine what normal weekly maintenance would prevent this, short of disinfecting and drying it every time.
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Posted on Jul 23, 2013
  • 27 Answers
Most mildew type deposits in the boot gasket (rubber thingy) are caused by over powdering and low temp washes try a washing machine cleaner and try lowering the amount of detergent and a 60 or 90 deg wash every month
bad smells are usually caused by if you have a stand pipe drain the lower end of the hose is sitting permanantly in water and syphoning back into the appliance
Posted on Mar 09, 2009
I think this originates from a loosening of the seal between the grey rubber and the door itself. if it is tight enough the water may not seep as much into the area within the grey rubber.
Posted on Mar 04, 2009
Always leave the washer door open after use to allow inside to dry completely. Any remaining moisture invites mildew.
Posted on Apr 04, 2008
SOURCE:
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water won't heat; door won't open at the end of cycle
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Oct 07, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
439 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
