Question about Dell UltraSharp 2007WFP Monitor
Horrible display black shadows, not sharp
Less than a year old,no phone support, cannot be used for
photo ediiting, causes nausea and eyestrain
  • 472 Answers
Your description isn't the best from a technical point of view, but this may help.
It is possible that you have purchased this from Ebay or some other means. The LCD panels used in most monitors come from only a few sources and all have some (a very small number) panels that are not 100% and are sold off as such on online auction sites cheaply.
If that is the case, then turn it into a TV for the kids to watch and get another monitor for yourself.
Posted on Apr 08, 2008
  • Peter Thompson
    Peter Thompson Apr 18, 2008
    Have you got the monitor set to it's optimal resoloution?
    If you havn't it will make it all look very ugly.
    Also make sure your video card can support the monitor, especially having a DVI out port and using a DVI cable.
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Tv went black no sound either. TV only five years old,is there anything i can do? Thanks James
Cannot offer solution but my mine has also gone bad.  At first a black shadow appeared on the left side of the screen.  Took it to the authorized service center.  they kept it a few days, said nothing could be done.  Used it anyway for the next 5 years when suddenly it went black (or sometimes blue) after working perfectly for the first 5 minutes. A sharp rap next to the right speaker fixed it a few times, but no more.  Good luck.
Bill
kepner13@olympus.net
Jul 18, 2011 | Maxent MX5020 50 in. Plasma Television
My 3 year old daughter was wiping our 50" Sony SXRD LCDTV with Lysol wipes. I didn't see where on the tv she was wiping, but know the bottom corners of the tv are totally blacked out and a black...
It sounds like she may have cracked the LCD display.
LCD (liquid crystal display) are very delicate nad any impact, even by a three year old could damage the screen beyond repair. Could you please submit a photo of the screen when on?
Oct 12, 2017 | Televison & Video
Shadow along edge of my SHARP DM-3551 copier's copies
Run a page with the cover or document feeder open. Just a solid black page. If the shadow runs completely edge to edge on the paper, your problem is in the drum unit or less likely the fiser.. If the there is a clean edge delete, then the problem is either dirty scanner mirrors or the laser. It is far less likely in the optical/laser system but still likely. I tend to believe the problem is in the drum unit.
Mar 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
I have an old (5 years) DELL PC with a CRT monitor. Of late the display has on the screen appears to be vibrating a little. This is causing eyestrain. The brightness, clarity & colours of the display...
The monitor is probably faulty. To determine if the monitor or the video card is faulty, connect a different monitor to your DELL. If the image is OK on the other monitor then the other CRT monitor is faulty. Repairs to the CRT monitor may not be a cost effective solution, I suggest you buy a LCD monitor.
Feb 05, 2010 | Dell Dimension 3100 PC Desktop
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
Unable to delete photos on t303
go to organizer, then file manager this will take you to camera album where you can delete pictures
Mar 29, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Blown Picture
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Aug 18, 2008 | Samsung FP-T5884 58 in. Plasma Television
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Dell UltraSharp 2007WFP Monitor Logo
88 people viewed this question
Alun Cox
