Question about Compaq (283983-001) Motherboard
Pin alignment on motherboard for led switches
How do I plug the Power LED pin, the reset LED, the HDD led pins on the compaq 283983 001 motherboard
  • 4 more comments
  • Anonymous Jun 02, 2008
    I have motherboard 283983-001 but i have 18 pin con.(no 10pin)(P5)
    pleace help me for thise same problem. [email protected]
  • corvin Jun 02, 2008
    I have motherboard 283983-001 but I have 18 pin (no10 pin) P5, plece me for thise problem.
  • Anonymous Jun 30, 2008
    Same Problem as the other guys.
  • anggitiarahm Nov 21, 2008
    how do I plug the Power switcpin, the reset switch,.
  • Robert Estabrook
    Robert Estabrook Jan 20, 2009
    Does any one know what the correct compaq part number is for the front panel power switch for this Compaq 283983-001 Intel 845 mother board is? My old switch does not fit it. also anybody know where I can buy one?
  • Benny Dow
    Benny Dow Feb 13, 2009
    Is there a schematic for this motherboard?
    Genius:
  • 1,027 Answers
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Posted on Apr 01, 2008
    Problem Solver:
  • 3 Answers
I've been where you are and I did a lot of research in addition to contacting Geeks.com from whom I purchased the mobo.
Here is the HP link to the drivers. This motherboard is for a Compaq Evo D510:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97128&prodTypeId=12454&prodSeriesId=316510&swLang=8&taskId=135&swEnvOID=1093#120
The front panel, audio, USB pin locations can be found as the other posts have indicated. Download the manual that was provided on one of the posts.
Also check out the solutions on http://www.daniweb.com/forums/thread155702.html. Scroll down to the post by "Cruzen1950".
Posted on Nov 08, 2008
  • 3 Answers
I connected the same as Intels D850 board.
http:/support.intel.com/support/motherboards/desktop/d850gb/sb/cs-013238.htm
Posted on Feb 17, 2009
Http://download.intel.com/support/motherboards/desktop/D848PMB/English.pdf
Look down toward the bottom of manual (above) and there it is. P5 set. Has picture also.
Posted on Nov 07, 2008
SOURCE:
Motherboard User Manual For SiS965L?
SiS965L is a chipset designation, not a motherboard model number. That said, most motherboards do label the header pins for the front panel connections on the motherboard, though they are a bit small and sometimes are not adjacent to the pins themselves. The Power Switch and Reset Switch pins are not polarized, and when you determine which they are, the connector plug can be installed on them either way. The Power LED and HDD LEDs ARE polarized. The positive pin is marked with a "+" sign and the Green wore of the Power LED and the Red wire of the HDD LED must be on the "+" terminal.
Nov 09, 2015 | Computers & Internet
How to re-wire a Compaq Presario SR2150NX Case power Switch
The plastic front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
F_PANEL_1
The Front Panel header contains connections for the Power On switch, Power On LED light, HarDDrive activity LED light, and so on.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864922&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339274
(Look at the motherboard photo. The Front Panel header is at the bottom right. Scroll down for the motherboard illustration )
There are 9 contact pins.
4 across the Top row, and 5 across the Bottom row.
The four pins across the Top row are numbered EVEN.
From the Left side going towards the Right side;
Pins 2, 4, 6, and 8. There is NO pin 10, just a blank spot.
The five pins across the Bottom row are numbered ODD.
Pins 1, 3, 5, 7, and 9.
A) Pins 2 and 4 are for the Power On switch
B) Pins 6 and 8 are for the Power On LED
(LED is dim when the computer is on? Switch the wires around )
C) Pins 1 and 3 are for the HarDDrive activity LED
(LED is dim when the harddrive is operating? Switch the wires around)
D) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
How to know which wires are for the Power On switch, Power On LED, and HDD LED?
Follow the wires into the Front Panel. Remove the Front Panel, and follow them.
(Need guidance removing the Front Panel post in a Comment )
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2012 | HP Compaq Presario SR2150NX PC Desktop
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
pin
Feb 02, 2010 | Compaq (283983-001) Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Front Panel Connector: JFP1 hookup
You can go to the link below and see the directions for that. Turn to page 2-17
http://www.premioinc.com/pc/manuals/mb/m266/m266.pdf
Sep 21, 2008 | MSI MS-6390 (-6390-010) Motherboard
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Compaq (283983-001) Motherboard Logo
2,348 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
