Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Username and password length
Is there a limit on the length of a username and password for this router.
I have changed both the username and password and now when I put it in I cannot get to it.
my current username is 28 characters and my password is 20 characters.
  • Anonymous Mar 22, 2014
    Need a username
  • 667 Answers
Are we talking about the user name and password just to get into the router? Like the default is admin and the password is just left blank? I don't think there is a limit but you don't have to go really crazy here. Once you change it from the default make sure you write it down and keep it someplace you won't lose it. You have to type it in just the way you put it in when you changed it like: PaSSwoRd . Exactly the same. If you think you maybe might not have it exactly or don't have it written down ( not likely since it's so long), the only thing you can do is reset the router to factory defaults. Just press and hold the reset button for ten seconds. Make sure you don't unplug it during this time. I've included a link for the manual in case you don't have yours. If this helped you fix your problem please rate. If the problem is with a different password just add a comment and I'll be glad to help. Thanks.
Posted on Apr 01, 2008
How do you change your username and password on your belkin router
It is refering to SSID - user, and Key - password under wireless options.
Dec 26, 2012 | Computers & Internet
How 2 put the password?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
Buffalo - Username: root Password: Leave the field blank Default IP address is:
D-Link - Username: admin Password: Leave the field blank Default IP address is:
Encore - Username: admin Password: admin Default IP address
Linksys - Username: admin Password: admin Default IP address
NetGear - Username: admin Password: password Default IP address will be: or
TP-Link - Username: admin Password: admin Default IP address
TrendNet - Username: admin Password: admin Default IP address
Zhone - Username: admin Password: admin Default IP address
Zyxel - Username: admin Password: 1234 Default IP address
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
How to program to my new enternet connection
HEllo bro...
I don't know what model that use, however here the best explanation for you..
1. Username and password for router.
2.Username and password for provider internet.
3.Ethernet cable (rj45 connection)
5. Pc /laptop to setup router ( on step i'm referred to pc)
4. Web browser( more preferred to using internet explorer current version)
1. Plug Ethernet cable to router
2. Plug another end Ethernet cable to pcthat you are using to setup
(Now you have cable was connected between pc and router)
3.Switch on the router.
4.Open web browser. Or click here
5.Some window will popup
6.Enter the username and password for router. If default( mean you don't change username or password,you can leave blank for username and fill password with "admin")
If still can't enter try search at google with your model and brand for username and password default.
7.After success enter, then using the wizard .
8. Fill the username and password for provider.
For step 7th, to 9th, you can directly go setup internet connection( depend to model, sometimes it just type setup) where you will find ppp username and ppp password.. change it..
Good luck and be careful. sometimes you make it right but router need time to create new connection..
For the best go here Lynksis setup
Jul 06, 2011 | Linksys Cable Modem
How can i reset the dlink
It have button for reset. click in 10 seconds.
iF YOU DONT WANT TO DO THAT, because it will reset to factory setting
So how to reset without lost username password?
type at your browser
FILL USERNAME AND PASSWORD. that is for modem router username and password.
if you never change,then try
May 13, 2011 | D-Link DIR-600 Router
Change user name
Please indicate the Model of the router you are referring to.
If its Cisco, first do a no username xxx password nnn command on the existing configuration. Then on the global configuration mode insert a new command with the new username and password. See example below:
#configure terminal
(config)# no username old-username password old-password
(config)# username new-username privilege 15 password new-password
(config)# exit
# wr memory
May 05, 2011 | Computers & Internet
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
I need to limit access to my wlan router. How do I do it? I typed in the address bar of the Internet Explorer and hit enter. I then typed admin in the username box and password in the password...
You could try "admin" as the username and "password1" as the password, or "admin" as the username and no password. If neither of those work, you might have to contact Linksys tech support.
Once you get into your router's settings, there are several things you can do to limit access to your router. The first thing is to change the default password. You can also change your network name (SSID), enable MAC filtering, or turn on WEP, WPA, or WPA2 security, depending on which options your router and computers support.
Jun 22, 2010 | Computers & Internet
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Limited access
If you have limited access, that means you need to change the wireless channel of your router. Using your wired computer, open the router's setup page by going to internet explorer and type and press enter. It will prompt you for username and password. By default the username is blank and the password is admin. Look for wireless tab and look for wireless channel. Change it to channel 11. Make sure to take note of the Wireless Security key as well under wireless security tab. Save the settings after changing the wireless channel. On your laptop, make sure to disable any firewall then try to reconnect to the wireless network.
Apr 25, 2009 | NetGear DG834G Router
Can't login to
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Apr 13, 2009 | Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
77 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
