Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
MDC4650AWW Portable Dishwasher
I hear a strange noise during the wash cycle like a "grinding" . It almost sounds like something small and metal is stuck in the soft disposer and making a ratchet sound. I've run my fingers around inside (unplugged, of course) and can't find anything. It's only 6 months old and I love this appliance so I need a quick fix, if possible. Thank you.
Kirby
  • poivriere Aug 13, 2008
    Ours is only three months old, and although it was quiet when we got it, it too has begun making this very loud grinding noise. Last night was the worst: Many times during the washing process, the machine sounded as though it was actually screaming!
    We have tried repositioning dishes on the racks and have even run it without dishes to see if it's a problem with the way we have been loadiing it, but it grinds and screams even when run empty.
  • smallhottea Dec 11, 2008
    same grind metal noise when turned on move dishes ...still making noise...help...
We've had a similar problem. A banshee screaming noise that's makes the skin crawl. Since our machine is well out of warranty I took the insides apart and found only a few cherry pits. (Lesson learned, always scrape your dishes before loading.) We covered out ears for a few minutes and the bad, bad noise went away. But the noise came back, it didn't stay away.. So here's what I found with more tinkering.
1. Problem: Small hard things can get lodged in the food mill/grinder assembly at the bottom of the dishwasher tub. It's there to cut up the big chus of organic matter I presume.Today I found a thin piece of plastic about an 1" long that got caught and was resisting being ground(even though we know resistance is futile) by the grinder thing. Anyway, I took the offending piece out, put it back together and the machine is working fine. I have a hunch that the first instance may have been one of those stray cherry pits that broke up enough to get caught.
2. Solution: take apart inside assemblies to get down to the "foodmill" like thingie and see if there's something hard organic or unorganic causing the noise. Discard. Put back together and hope that solves it. (It did for our machine)
3. What's needed? Good knees or a decent knee pad and a few simple tools as follows:
A. 1- medium flat blade screwdriver
B. 2- TORX screwdrivers, # T-15 and T-20, or equivalent bits for a portable electric drill/screwdriver.
C. Small pair of regular pliers or simialr tool.
D. Muttering under your breath like Fred Flintstone, or not.
4. Process:
Take out the water jet assembly. It is held by a clip at the back and top. Use the screwdriver to pry the tabs away from the clips, then pull the assembly out at the bottom where it connects. It's a simple slide in/out fit. The bottom whirlygig water jet is fastened with a threaded cap that can be removed with the pliers. (BTW, this can get clogged with gunk. while you have it of check for gunk. Then, keeping track, remove the remaining hardware with the TORX #T-20 screwdriver until you get to a round black piece. The black piece has to come off before you can remove the piece with the filter and grinding screen. Use the #T-15 bit for removal of the black piece. Then remove the rest 'till you see a "blade". Hopefully in that process, whatever was causing "the noise" will fall out and you can discard it. Observe how gross it is in there, shudder, and begin the process in reverse.
I do have some pictures of the process in stages if you want. E-mail me at: gpfn47atyahoo.ca (note: please use the "@" symbol to replace the "at")
Well, that's it. I hope it helps someone.
Have a Blessed New Year!
Greg F-N
Posted on Jan 06, 2009
I have a Maytag portable dishwasher that is almost 2 years old (MDC4650AWW). My problem is that is doesn't drain completely. When it tries to drain, it trickles out of the hose. In fact, most times I run it, there is about 1-2 inches of water on the bottom of the dishwasher left over so i don't feel the dishes are actually being rinsed clean. When I pull the hose in and out while it's draining, it tends to come out better. It's as if something is stuck in the hose. has anyone else had this problem and fixed it?
Posted on Dec 05, 2008
  • 487 Answers
Kirby
If this machine is only six months old diy fixing might void your warranty.
Call service guy first
Posted on Apr 23, 2008
SOURCE:
My Maytag PAV2200AWW Washing Machine makes a noise like grinding or metal-metal contact during the agitate cycle. How can I fix it?
The sounds of 'metal grinding/banging" begs the question of whether or not its even safe? If you hear that sound all the time or as you say ONLY during the agitation cycle suggests that you be able to service the tub/motor mounts in the underneath chass--which is a heavy-duty technician job. A Maytag technician has the tools you need. Or the obvious...get another one from a friend who is upgrading to a new washer and hands it down to you for a little change.
Dec 12, 2015 | Maytag Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Problem during wash cycle
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Mar 19, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
My dishwasher makes a grinding noise during the wash and rinse cycles
It sounds like something foreign got into the machinery. Exploritory surgery is the only solution.
Jan 21, 2011 | Maytag MDB6701AWW 24 in. Built-in...
My dishwasher is just 6 months old and started making a humming sound while washing in th wash cycle.
If you hear unusual noises during dishwasher operation, check to see if a dish or cup is loose and being knocked around during the wash cycle. If you hear grinding, grating, crunching or a buzzing sound, chances are a hard object has gone into the wash module. Once the object is ground up, the noises should cease.
Apr 03, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
947 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
