-   My Frigidaire washer shakes the whole house and even put a hole in my new wall when in the spin cycle! Help!-   ystergarde
Jul 02, 2008
-   my propane washing machine "dances" around the room as it spins. Any suggestions? I am afraid it will pull away from the propane line so I have to physically hold it in place (or at least try) as it goes through the spin cycle.-   sburns1045
Washer leaks all out the front door. Tried cleaning rubber around the door, and still no luck. ...
(More)
Washer leaks all out the front door. Tried cleaning rubber around the door, and still no luck. tryed spinning water out but when i tried to get a ''just spin'' program i wasnt able to find such a program, so it filled up and then read ''ie'' on the main display and quit running leaving the tub full of water and it was leaking so bad threw the door, it was running all over the floor. so i had to open door slowly and vacuumed it up as it came out. I wondered if it only leaked because the tub was half full of water and it was to much pressure? I checked and the taps are all working as well. checked filter and checked outlet hose, everything seems to b fine. Any suggestions??
