Samsung Silvercare hums, but does not run
Samsung silvercare washer started a load. It washed, rinsed and did the second wash. At some point in the second rinse, it stopped. When I walked into the laundry room, it was humming, but not running. I waited a bit. Nothing changed. So I paused it and change the setting to spin. It hums but nothing happens. There are no codes being displayed on the front panel. Tried starting a new wash selection. Humming but no action.
  • Anonymous May 08, 2008
    my washer does the same thing hums but does not fill or spin can you tell me the codes for it?
    Thanks TimĀ
FIXED!!!! amen. Attached to the back of the washer was a plastic bag with a tech spec pamphlet. Inside the pamphlet were instructions for running tests via the front control panel on the various cycles to weed out the problem -- fill, spin, drain, etc. The test failed on the draining section citing a problem with the drain pump. So long story short and MANY towels later, I found a small finishing nail in the motor. I had removed the hoses thinking there might be a blockage, but found nothing. So I removed the motor and washed it out. Nothing odd there. So I took the front off the motor and found the nail. It somehow made it through the drain holes in the washer drum but got stuck in the motor.  Thank you Samsung for taping the tech manual to the back of the washer. I could not find it anywhere on the web for this model. After discovering the testing available via the contol panel and the simplicity of the machine, I love Samsung.
Posted on Apr 03, 2008
SOURCE:
I keep getting E3 on my Samsung silvercare technology washer
this can be many thing, a hall sensor,bad electrical connection,faulty motor etc, one thing you can try is unplug the machine from the wall for at leastthree minutes and try again
Dec 30, 2017 | Samsung Washing Machines
When the washer mark nd,what that mean?
SAMSUNG Silvercare Front Load Washer will not drain ...
? 3:06
www.youtube.com/watch?v=JozFGnPsQvA
May 4, 2013 - Uploaded by eallevato Troubleshooting a Samsung front load washer that is displaying ...Ordered a new pump and still no spin and "nd" code comes on after a while.
Sep 27, 2015 | Washing Machines
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
Have samsung silvercare front loading washer....received and error code of ND what do I do?
"ND" means "Not Draining". I have the same washer, and when I get this problem, it's usually because I've tried to wash something that is causing over-sudsing (like a bath robe that was previously washed in an inefficient washing machine which left a lot of soap behind).
I find that turning the machine off, then selecting "Rinse and Spin" works. I suppose if it's a serious Not Draining problem, it could be that the drain hose is clogged somehow -- start by making sure they're not kinked.
Jul 20, 2009 | Samsung WF337AA Front Load Washer
I just bought the samsung SF448 steam washer. There is one problem. The ''preset'' wash cycles are supposed to be just that. If I choose the normal cycle but add another feature such as steam or...
why not do the special cycle and set it as "My Cycle". that way you can keep that one special setting under this cycle and use it every time you wish to use that particular setting
Mar 08, 2009 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Samsung Front Loader Washer Out of Control
make sure you take out the 4 srews in the back of the washer .
This is only to hold the drum in place when it is transported to you
Remove them and you should not have a problem.
This info is only for front loaded wahers and not dryers or top loaded washers
Mike T.
[email protected]
Washing Machines Logo
677 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
