Question about Lite On LVW-5115GHC+ DVD Recorder
Dvd writer w/lightscribe
My dvd writer comes with lightscribe feature,when im finish making the cover it says go to file button and click print lightscribe but it don't say that it just has the regular print. is there another way or do i have to download something
    Sergeant:
  • 366 Answers
See http://www.lightscribe.com/ for explanation.
Posted on Jan 19, 2009
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
Can i Print CD/DVD labels with this printer. Directly to disc?
I just checked Kodak website and this product doesn't mention such a feature. I think only Lightscribe can draw on the dvd/cds. This only comes on the DVD/CD writers.
Feb 23, 2011 | Kodak ESP 5 Printer
HOW DO I PRINT CD LABELS
download light scribe app. if your writer is light scriber enabled which prints on CD/DVD as per the selection made through lightscribe app. else you print CD label through NERO 8.0 which has amazing feature of nero cover designer.
these apps. are self explanatory and will automatically guide you and help you create CD labels
at your ease.
thanks and regards
kindly rate this solution
FIXYA-simplifing your problems
Feb 11, 2011 | Computers & Internet
I have a PC Pavillion with a Lightscribe DVD Writer - CD Writer ...I have had the PC for 4 years...Inserting a CD in the Lightscribe..I cannot read any files.....does not work with an audio CD either...
Click Start
, and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
Exit Registry Editor.
Restart the computer.
Nov 19, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Problem with hp dvd writer 740b
make sure all the cords are hooked up to it properly in the computer case and if they are hooked up tight and none are loose make sure you have music/dvd codecs on your computer get a codec pack and then it should write a cd like normal for a codec pack just go to google and download one doesnt matter what one
May 29, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
HP DVD 1040 external lightscribe
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left pane if is already started and set to automatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
Dec 16, 2008 | HP DVD1040e DVD-RAM Burner
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Lite On LVW-5115GHC+ DVD Recorder Logo
    56 people viewed this question
    Top Lite On Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
