Question about Sony Playstation 3 (PS3) Console
Blue ray problems
The power wire is broken and i want to replace it but dont know where to get the same connecters and wire
  • 27 Answers
If you are talking about the PS3 you can use a standard IEC cable, commonly known as a Kettle lead, and can get them from any electrical hardware store for next to nothing. Chances are you probably have a spare one around the house somewhere, most PC's and monitors also use the same plug.
That's if you're talking about the PS3.
Posted on Apr 03, 2008
Does the blue wire need to be connected to 12 V + . if I have no accesories, can I just leave this wire disconnected? thanks!
The subject shows this referring to a Pyle car amplifier. Is that the case? Either way this will hopefully answer your question.
If you're talking about the blue wire from an after market car stereo and:
  • There's no accessories (as you've already stated)
  • You don't have a power antenna
  • and you're not running an amplifier
You can leave the blue wire disconnected.
If you have a power antenna it'll need to be connected to the corresponding wire in the dash (I would need to know year make an model of the care to help you identify that wire). If you have an amplifier the blue wire would be run directly to that.
Hope this helps. Let me know if you have any questions.
Thanks,
Ray
Jun 16, 2011 | Pyle Car Audio & Video
I wanna connect my amp, and i dont know which is the remote wire? where do i connect the blue wire to? i have a sony cdx-f7700. can anyone help or have a diagram
The blue wire, if you've not got a corresponding blue wire to connect to can be connected to the ignition wire. That being one of three needed to power your head unit - RED (12v permanent), BLACK (negative / earth) and another colour, sometimes blue for 12v ignition (only comes on with the ignition on / acc).
Aug 20, 2009 | Car Audio & Video
Trying to figure where all the wires connect on a/c contacter?
The two wires coming from your inside unit. They are the low voltage wires go on either side of the contactor coil. You should not have two blues on one side. see if the black wire comes from inside unit. Rus
Jun 25, 2009 | Coleman Heating & Cooling
Dont know how to connect
Just click and choose whatever hooked up connection you want; DVD Players/Recorders: Home Theater Setup, Installation & Hook Up .. * Audio and Video Connection Guide * What is HDMI Technology? * HDMI Explained in Detail * Audio and Video Definitions Plasma or Video Projector Wiring Guide Blue-ray Surround Wiring HP TVs - TV Cable and Connection Types Hope this may help; Regards, VOTIT
Jun 08, 2009 | Wharfedale Moviestar 60+ System
I have an 1984 rudd 75,000btu forced hot air unit with pilot light, while cleaning unit an electrical connector broke off ! it looks like a blue plastic wing-nut, and It has 2 large black wires that go to...
The simple diagram for that specific problem it connected series to thermal cut off sensor.
The two black wires, One came from a power supply line (it means an active power
and the other one goes to the load motor) If you shorted it connection it will run the motor.
But it bypass the sensor.
Unplug the power then try to fix the both end of that black wire connected to terminal bolt of your thermal sensor by replacing the broken plastic nut with a new one.
Fit the nut thight to avoid electrical arch while giving power on at the start.
r_ic7
Nov 29, 2008 | Heating & Cooling
Car stereo wiring installation
red wire connect to accessories or constant power 12volt
black wire connect to earth /ground/ metal
yellow for clock and memory connect to permanent power
blue wire connect to amplifier
2x rc connect to amplifier
8x speaker wires connect to 4 speakers
just ask if you need more help glenn..........
Nov 22, 2008 | 2005 Mitsubishi Lancer
Amp works when beaten
It sounds like you have a broken connection in the amplifier. The first thing to check is the fuse. Sometimes the contacts become weak on the fuse holder and the connection becomes intermittent. Any other troubleshooting would require opening up the amp. Any repairs would require resoldering the broken connection.
Let me know if you have any other questions.
Sep 22, 2008 | Jensen XA2250 Car Audio Amplifier
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
