An audio CD was inserted in the cyberhome CH-DVD 300, TV screen shows "LOADING" but nothing happens. The unit continues to run, will not respond to any inputs via buttons or remote, the disc tray will not open. Can you help me resolve this issue?
  • 1 more comment
  • rltaylor5498 Apr 01, 2008
    Correct...a traditional audio CD
    I suspect the CD was inserted improperly and has locked up the player. If so, is there a way for me to open the player and relieve the problem?
    Any help will be appreciated.
    Genius:
  • 1,665 Answers
See at the front of disk tray if there is a nedle hole. You may release tray inserting a needle there and push tray latch.
Posted on Apr 01, 2008
    President:
  • 1,944 Answers
Did you try disconnecting the unit from the power for a few minutes? If so, what happens when you reconnect?
  • 59 Answers
This was a traditional audio cd, that would run in any normal cd player, correct? not a CD with mp3's saved on it or something?
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
Trying to get unit to play
well try unplugging everything then set it back up and switch some cords around....if nothing happens take then or it back ...best of luck :)
Aug 16, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 can't read CD
Why don't you call manufacture and see if can get service.
Wont load any DVD'S
It is possible that the power supply is not providing a solid 5 volts.
Many of these units had problems where the 5v is too low (4.9).
In most cases capacitors can be replaced to correct a low voltage situation. Be sure to use 16v capacitors in place of any 10v.
Feb 18, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
It does not want to load anything.
have you tried resetting it to factory defaults?
Jan 10, 2008 | Cyberhome CH-DVD 300 DVD Player
Region Error
this is for: Cyberhome CH-DVD-300 1. Ensure the players disk tray is Closed with no disc . 2. Press Menu. 3. Press 1. 4. Press 9. 5. A menu will appear with the region number near the bottom of the screen. 6. Press Enter. 7. Select the desired region. 8. Press Enter to save the settings.
Jan 31, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
