Question about Sony GV-D900 Mini DV VCR
As the power turns on and you eject, the chassis goes in automaticly
Hi, I need help, I have a this unit as you turn the power on eject to put the tape in, opens and right away the chassis goes back with you leting you put any tapes in and gives an error msg.
  • 180 Answers
The problem may be due to the misalignment of the cassette mechanism.remove the cassette block assembly and refix properly.
Posted on Apr 04, 2008
In tvs speed 40 printer all led light are blinking
follow these steps
1) Press ST1+READY button together
2)Turn on the tvs speed 40plus passbook printer
3) The 4 LED will blink 4 times. Release the button ST1+READY immediately after 4 blinks
4)PRESS ST1 - ST1+READY+EJECT starts blinking
5)again PRESS ST1 - ST1+EJECT+ST2 starts blinking
6)again PRESS ST1 - ST1+EJECT starts blinking
7)again PRESS ST1 - ST1+EJECT starts blinking
8)again PRESS ST1 - READY+EJECT starts blinking
9) printer is READY wait and PUT PAPER.
10) The paper goes in and comes out 3 times. will take about 2 minutes.
11) Paper ejects automatically after printing.
12) turn off the printer and turn it on.
Jan 24, 2014 | Office Equipment & Supplies
I can not eject a disc from the disc player. I've heard this is a common problem. Thanks. Curt Pasawicz
Hi curt730,
You're right, this is a known issue for years with Bose Lifestyle. You may try these steps to resolve the issue:
Note: You will need a flashlight and a small screwdriver.
1. First, disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Then, using the flashlight, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. The moment you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Finally using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in the player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Hope this helps.
Thank you for using FixYa.
Jun 08, 2011 | Bose Lifestyle 28 System
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cd-rw5000 stopped working
try www.free-service-manuals.com
14.00 for 3 months and a whole mess of manuals
I use it constantly.
Apr 07, 2009 | Computers & Internet
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
Cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Jan 27, 2009 | Blaupunkt Louisiana DJ32 Cassette Player
Player shows ejects symbol and shuts off after about 45 seconds
the timing will be out of line, thats whats putting in shut-down mode. dis-engage the tape carriage from the running cogs and manually put it in eject mode, re-align the main cogs to their pointers. there should be one on the cogs and on the chassis to help you re-align then re-engage the carriage to its cog.
Jun 13, 2008 | Sony SLV-D251P DVD/CD Player w/Built-in...
HOW TO DISARM THE CARRIAGE
a vcr carriage has at least one or maybe two little plugs going to it from the main circuit board, unplug whatever lines that are going to it. don't cut any wires.
Apr 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Sound goes in and out
cold solder joints on board.
Feb 22, 2008 | Jensen VM9020TS Car DVD Player
Sony GV-D900 Mini DV VCR Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
