Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My side by side fridge is not working.
Overnight the Freezer and fridge both stopped being cold. My ice melted and my meat defrosted. I laid it on its back and cleaned out the dust from the bottom of the fridge, I made sure that the fan was clean and free of debris. I noticed my compressor was hot when I touched it. I am not sure what I need to do to get it working again. Please help me! Thanks, Michelle
  • Dukegray May 03, 2008
    freezer only putting out cool air, cold temp control all the way down to -5, still not cold enough... frozen food is now de-thawing and water is all over.  No help from Kenmore help line!!!! they want $65 for a service call + parts and labor to fix problem.  Fridge is only 4 years old and its our second one since we bought all new appliances when we built the house, we also had problems with our Kenmore dishwasher....never buying Kenmore again!!!!!
Try checking the cold control. It sounds like that is out.
Posted on Apr 21, 2008
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Refrigerators
Maytag MSD2651HES fridge not cooling freezer works find
  • possible causes:
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
  • possible causes:
  1. bad defrost timer/board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer not cold, the meat is melted
Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
