I can't get inside door cover off to plug new cable into location.without damaging
Found this while looking to replace speakers:
DOOR WITH POWER LOCKS AND WINDOWS First remove the triangle piece in the top corner of the panel (piece closest to the outside mirror). This can be done with a plain screwdriver and just a little
prying and it will snap off. Second, remove the door lock inset, same screwdriver, little prying
and it snaps out. Next remove the cover inside the door handle, same screwdriver, pry and snaps out
(turn it upside down and slide it off. Now you will need to remove the cover that holds the window
and door lock buttons, same screwdriver and pry upwards just a little and should pop off. Ok now you
will need a small socket to take out three screws. One is inside the button panel you just took off,
the second is inside corner of the door arm, (the handle you grab to shut the door, look under it,,
see it yet, yeah thats it). The last screw in on the very bottom of the whole door panel, you will
have to get on your hands and knees to see this one. Now would be a good time to remove the door light on the corner, same screwdriver, pry from the red lens side outward, once out, remove the wire termial. Ok.... now grab the under side of the panel where that last screw was and lift upwards, apply a little more pressure till the panel pops upward about an inch. Now your door panel is loose, you can lift it off a little but you will need to remove the wire from the tweeter. The termial has a locking tab you need to press down to remove it.
SOURCE: replacing bronken mirrorbody w/new one, have mirror on long cable
The cover comes off from the top down, two clips one on the side by window other on top half way down angle part, pry out gently, bottom has a tongue that holds bottom in pull up after you release the two clips.
