The volume on my SX-790 is very low even when it's turned all the way up. I tried it with headphones and speakers and its the same volume level.
This can be caused by a number of things. Lets check the simple ones first:
1) Verify that the tape monitor switch is not ON. If it is in the monitor position, the low volume will be the "cross-talk" only and be very weak.
2) If not #1, then you likely have defective transistors in the ouitput section or have a power supply problem. With the B+ voltage mising, you will be attempting to drive the speakers with the "driver" circuit rather than the output section. This can also occur if the transistors fail "open" rather than "shorted".
Check the tape monitor switch and update this with the results. We will continue from there.
Dan
