Need tweeter housing for pce 213 1.inch - Audio Players & Recorders
  • 19,396 Answers
SOURCE:
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
What size are the tweeters in a 2000 gmc sierra extended cab truck? In the door, there are 2 sets of speakers. The 6 3/4" and another smaller pair. What is the size of the smaller set? I have a 2000...
Hello.. the tweeters in the doors are 1 inch tweeters, but they have a large housing. Every set that I have come across are usually hanging because the 2 plastic nipples that go through the panel break off. They have a self-threading bolt on the back and they all eventually come off. You can rotate the tweeter slightly and run a panhead screw with a stinger tip to keep them up. If you are adding a pair of tweeters, just leave those in the door panel and just remove the metal grille that covers the speakers and add them next to the factory ones. You can just wire them in with the factory wiring. Just be sure to wire it on the door panel clip side so you can remove the door panel without having to cut the wires every time. You will have to remove the panel to gain access to removing the metal grille on the panel. Hope this helps! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | Car Audio & Video
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
How do i install my component
from the speaker outputs of the head unit / amplifier. Connect from the positive and the negative outputs to the respective positive and negative input of your X-over box. Now connect from the X-over woofer/midbass output to the bass driver. Now do the same for the tweeter from the X-over from the tweeter output to the tweeter. Make sure that all the positives and negatives are correctly connected.
If you are going to use your head unit to power the speakers then you should know that:
White & white with black stripe is the Front Left Speaker output
Grey & Grey with black stripe is the Fron Right Speaker output.
Green is rear left
Purple is rear right.
I think you get that the black stripe speaker cables are the negatives.
good luck
dreamsystems.
Feb 11, 2011 | MB Quart - 5.25" 2-Way Component Speakers...
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl ([email protected])
May 12, 2010 | Audio Players & Recorders
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
I need 2 know what size speakers go in the front doors, 2002 gmc.
Those are 5 Inch Speakers and Tweeters I do Believe.
Jan 10, 2009 | 2002 GMC Sierra
I have a pair of pioneer cs99-a speakers and i need the tweeters and the horn tweeters repaired is this possible if not were can i get second hand parts from cause i need a 4 inch and 5 inch midranges that...
hi i solved the problem with the super tweeters. two of them didnt go so i pulled them apart and got the voice coil and unwound it enough to solder it back on to the terminals.they both go excellent now took about a hour well worth the time.
Nov 29, 2008 | Pioneer Audio Players & Recorders
M-Audio MX8a tweeter replacement
Remove the six hex screws from the plastic front speaker housing. It\'s the piece with the speaker\'s make and model imprinted.
Gently pry the cover off. The blue LED light can be easily freed by gently prying it loose from the back of the plastic housing. You\'ll notice the two wires connecting your tweeter. Don\'t pull too hard on the cover while the tweeter is still attached to prevent detaching the wires. Instead, take very short, stubby Phillips head screwdriver and remove the two screws holding the small plastic brace against the back of the tweeter. It\'s a tight fit. Don\'t pull too hard on the wires! Next, push the tweeter out from the front, touching only the extreme outer rim. Or, use needlenosed pliers to grip the heat sink on the back of the tweeter and gently pull from the back. The tweeter has a very powerful magnet. Find a small but robust rectangle made of ferrous metal. Large enough to span the front diameter of the tweeter. When the speaker magnet grabs the little metal plate, adjust the plate until the buzzing stops. This means of course that you have to turn the power to the speaker on.
May 28, 2008 | M-Audio Studiophile BX8a Speaker
37 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
