Question about Sanyo DS27930 27" TV
Sanyo DSC27930 No picture, no sound but seems to have power.
My wife and daughter were watching TV recently when they heard a pop or crack like sound then suddenly there was no picture and no sound. Naturally the warranty had already expired....two years ago. Local repair shops want $150 to $300 to look at and or repair the thing. That is not practical for us seeing how the TV is almot four years old. We can't afford one of the newer flat TV's on the market now either. So, I pulled the back off the TV but did not see anything obviously wrong. Even the fuse looks okay. I was careful not to touch certain things and have done nothing to the TV so far. I'm thinking of trying the get a new fuse at Radio Shack, though I don't know if that will get the TV working again. Anyways what went wrong with it and can I fix it without it costing too much?
Thanks.
  • 2 more comments
  • D. Lock Apr 03, 2008
    I had a frined check out the fuse to day. I forgot what electronic tool he used but it showed the fuse to be good. Besides the fuse does not look blown. So, I guess the fuse is not the problem. Right?
    Thanks. I have checked for damaged, burnt or loose parts. I saw nothing burnt, or damaged to my knowledege and nothing was loose.
    Could be something messed up that is not obvious? Or, what else might be causing the TV problem?
  • Anonymous Mar 01, 2009
    where is the fuse at?
  • sabrin733 Apr 13, 2009
    i have the same problem but someone told me it may be the bulb????
Hi there!
My guess would be that you had a surge on the mains power. check for damaged or burnt parts in the power supply and or Line Stage. sometimes transistors and/or IC's can blow off a piece of the package. So check those as well. I do not have any info on this model but the specs are pretty much the same as any other Tube TV. Regards and good luck, JUS004
Posted on Apr 03, 2008
    Scholar:
  • 135 Answers
Hi there!
Something did Pop and yes it will cost 150 - $300 to repair. The question is what would a new unit of the same size and quality cost. If the repair is about a third of the cost of a new unit , it would still be considered economical in RSA. If repaired it may run again for another 4 years so the Math speaks for itself. The decision entirely yours in the end. It could really be anything that popped so to give advice would be difficult. However, try the fuse first. It is certainly the cheapest option at the moment. Regards and good luck, JUS004
Posted on Apr 02, 2008
  • Justin Smith Apr 03, 2008
    Hi there!
    This will then require skilled labour to measure and determine which part went faulty. Blown parts are not always obvious so they have to be found with test instruments like a multimeter and then one has to know how to measure the different components. Unfortunately I can't assist any further. Perhaps if I was closer. Regards and good luck, Jus004
SOURCE:
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Jul 28, 2017 | Samsung Televison & Video
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I was watching my Hitachi 42hdm12 and heard a pop and now the picture won't show up or sound or anything?
A pop is usually a power surge and you blew a board. If you take the tv apart, if this is it, it will be evident by the burn marks. You could have burned out the internal power supply as well.
Oct 04, 2012 | Hitachi P50H401 50 in. Plasma HDTV
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
Sanyo DS27930 27" TV Logo
181 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
