Question about Yamaha RX-V1500 Receiver
RXV 1500, I am unable to get 5.1 audio
I have set up the receiver with a Bluray player and a DLP TV 1080i.
The audio does not seem to be working correctly
In an attempt to resolve the issue I just changed some cables.
I now have an HDMI from the bluray straight to the TV and a toslink cable from the bluray to the DVD optical input.
The diplay on the amp shows PCM. I ran through the amp and bluray config settings and they seem to be set to 5.1 sound.
The display on the amp shows L and R speakers only. The center, surrond and sub do not light up. My brother has an smaller unit and his lights up all 5 speakers
i have tried changing the input mode, only auto detect works.
Suggestions?
  • 1 more comment
  • Anonymous Nov 09, 2008
    same problem with same hookups. 1080 P Plasma TV and Playstation 3. Help please
  • mranthro Jan 14, 2009
    I have the exact same problem.  The speaker check function shows all my speakers hooked up correctly.  They light up in order when they are checked during auto setup.  But when playing, only front and left light up, as if only these were detected.
  • Repo Man Jan 15, 2009
    I thought that I updated all when I found the solution.
    The information from Yamaha was correct however you still need to check the digital audio output from your DVD, Bluray drive.
    Some if not all optical drivers I set to PCM for digital audio.
    To receive 5.1 or higher change the digital output to bitstream.
    Once I made the change I my sound was in 5.1.
    Why this information is so hard to find I am not sure. I have noticed that MS Xbox 360 and some Digital cable boxes change bitstream to read Dolby Digital. If all adopted similar changes this would be an easy settings change.
    I hope this helps
Just got off the phone with Yamaha customer support, who were very helpful.  The display on the amp, in the lower right hand corner, displays the source input, not the output.  So, for example, you can be watching cable tv, and the cable tv is sending a 2-channel stereo signal to your receiver.  Your amp shows only L and R.  But since it has a processing system, depending on the processing program you have chosen it will probably distribute that sound to all five speakers.  You will be confused, because you hear sound from all speakers but you only see L and R lit up.  You will believe that you are not getting 5.1 sound.  And you will be correct: you aren't, because the source is not sending you a five-channel signal.  That's where I got panicked.  So the Yamaha representative said, insert a DVD that you absolutely know contains a Dolby Digital audio.  I inserted Shaolin Soccer DVD, went straight to a scene in the middle, and bingo!  The center and surround right and left speaker lights lit up!  So there is the 5.1 surround sound.  It will light up when it detects that kind of sound from the source.  Otherwise it will probably give you a sort of "fake" 5-channel sound that it creates from a 2-channel source.
Now the question becomes, are your connections getting the 5-channel sound to the amp correctly?  I just confirmed that my DVD, connected with a Coaxial cable to the Yamaha, does get 5.1 surround sound, if the sound is encoded in the DVD.  I have not tested this yet with video games or Blu-Rays; I will post again if and when I confirm that this works on a PS3.
Posted on Jan 14, 2009
  • mranthro Jan 15, 2009
    OK, now I am even more confused than before.  As noted, the Yamaha was receiving only 2 channels, but when I put a DVD in my DVD player (not my PS3), it did detect 5 channels.  Great.  After reading your post, however, I decided to try the same thing in my PS3.  To my astonishment, the PS3 is outputting only 2 channels.  Ack!
    I went into Sound Settings, then Audio Output settings.  Then it asks you to select the cable you are using.  I have an HDMI connecting the PS3 to my HDTV, with a standard RCA connecting the TV to the Yamaha.  Then it asks me to select Automatic or Manual.  If I go to Automatic, I notice it says only PCM 2-channel output is selected.  So I go to Manual and check Dolby Digital 5.1 and DTS 5.1.  Then I save the settings.  But when I put in a Blu-Ray disc, the Yamaha tells me it is receiving only 2 channels (displays only L and R).  I go back into Audio Output settings, and the Dolby Digital and DTS boxes are unchecked again, and the Automatic is selected with only 2-channel outputs listed.  In other words, my new settings are not sticking.  As a result, I am not getting true surround sound through the PS3.  I will try to find the answer to this problem; meanwhile, any suggestions?
    All righty.  Problem fixed.  Like the rank beginner that I am, I was unaware that RCA cables are simply incapable of transmitting Dolby or other cinema surround sounds.  So when I sent the Blu-Ray signal to my TV through an HDMI cable, and the TV sent it to the amp through the RCA cables, the Dolby encoding was lost and all I got was Yamaha's imitation DSP, which is pretty good but not the same.
    So I went online and looked at a few other forums, and the solution was buying optical cables.  I got a 4-foot optical cable, and linked it from my PS3 to the "CD" optical input on the back of the Yamaha.  Then I went back into the PS3's Sound Settings and from there into Audio Output settings.  I selected the optical cable instead of HDMI.  Now the video signal goes through the HDMI cable to the TV, but the audio signal goes through the optical cable to the Yamaha.  I put in a Blu-Ray disc with Dolby Digital sound, waded through the menus, played a scene and ... bingo!  All 5 speaker lights lit up on the Yamaha, indicating true cinema surround sound.  Problem solved.
    By the way, then I did this nifty thing with the Yamaha where you can change an optical input's name, so now when I press "CD" it displays "PS3"... nifty.
    Now I have Dolby coming from the DVD player through a coaxial cable, and from the PS3 through the optical cable, both successfully; only thing left to mess with is the cable box.  I'm just waiting for a program I know to have Dolby sound to come on, and we'll see; I also hooked up the cable box directly to the amp with an optical cable.  But the DVD and Blu-Ray problems are definitely solved.
I have a VR-6025Z 60"
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
May 14, 2017 | Westinghouse LVM-42w2 Television
I have a Yamaha RXV-365 AV receiver. When I connect my Bluray dvd I only get the picture and no sound, I have an optical cable fitted into the back of the tv and placed it in theback of the reciever but...
You must connect from the Bluray both HDMI and SPDIF to the receiver, and turn TV volume down. TV does not send the sound
from HDMI inputs out digitally, only sound from TV channels.
Jun 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
Onkyo TX-SR606 takes up to 30 minutes to display 1080p
Please don't rate me for this. Onkyo has been having voltage problems with their HDMI boards in several models. Yours is one of them. They first instructed techs to replace some capacitors, then add some capaictors to repair the voltage problems. Now they want us to replace the HDMI boards but I have yet to receive any (on back-order) Sorry for the bad news.
Mar 23, 2010 | Audio Players & Recorders
The receiver is not keeping the signal from my blu ray player. there's no sound or image. if i plug the player straight into the tv, it works great. but my brand new receiver, r-v436 works like ****.
Your brand new receiver? that model is almost 4 years old? The HDMI version is generation 1 version 1.1 and riddled with problems. It's not a "Yamaha" problem, it's an "HDMI" problem. HDCP is the biggest issue (copyright protection) and pass thru firmware that is not forward compatable, which is why HDMI blows. Today's current version is 1.3b and supposedly has "fixed" all the issues. If your TV is 1080p and larger than 50" run your HDMI directly to the TV from the bluray. If your TV is 50" or smaller or 1080i, just run Component and digital coaxial or optical. Reason: The human eye cannot see the difference between 720p and 1080p on a screen 50" or smaller, that is fact. If your TV is not 1080p, and is 1080i, component still has it beat at 720p. I've been doing HD since 1995 and have dealt with all the issues! If your not sure if your TV is 1080i or 1080p just post a comment w/ your model # and I can walk you thru the best possible way to set your system up. If you just got the receiver "new" from a store, take it back. It's way behind the curve. Hope this helps
Jun 24, 2009 | Yamaha RX-V430 Receiver
RX-v465
Unfortunately the RX-V463's HDMI output is version 1.2 or 1.1. In simple terms, It is useless! Not to blame yamaha or any other manufacturer but the firmware was riddled with problems; just like what you describe. There is no fix for your model for the video issue, however, the optical issue is solveable. The receiver should play 5.1- 6.1 7channel stereo etc. in optical or coaxial mode. If you have the ability to switch to coaxial, do so. it's sound is warmer anyway. Secondly, check your settings thru the receivers "GUI" or "Menu" in Manual setup for audio. Thirdly, check your samsungs "Native" resolution, chances are it will only do 720p or 1080i and; if your TV is 50" or smaller, the human eye cannot see the difference between 720p and 1080p anyway, provided you use good cables. I am a professional in the industry and still avoid using HDMI whenever possible!
Just make sure you set your BluRay and TV to the same resolution. If your choices are 720p or 1080i use 720p it's cleaner 1080i is equal to 540p, which is just a hair over std DVD video. If you still have problems and need more help, post a comment and I will help some more. Hope this helps
Jun 11, 2009 | Yamaha RX-V463 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
480i is displayed on the tv even when I play my Sony BluRay
You have to go into the blueray player menu and select the type of output. And, yes the display on the TV will automatically indicate the type signal it receives from the source.
michtech
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Yamaha RX-V1500 Receiver Logo
949 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
