Question about Car Audio & Video
12 inch insignia subwoofers model # ns-sub12
I need the wiring diagram for these subs
How to wire 12 inch insignia sub woofers
Posted on Apr 13, 2008
You have to bridge them....
Posted on Jul 16, 2008
    Problem Solver:
  • 7 Answers
How to run the speaker wires from the subwoofer to the onkyo 7.2 tx-nr626
See Onkyo manual here: http://filedepot.onkyousa.com/Files/own_manuals/TX-NR626_English.pdf
Insignia manual:
http://audio.manualsonline.com/manuals/mfg/insignia/nsht51.html?p=1
Best hookup method for sub is to use the LINE LEVEL INPUT on the Insignia, wired with RCA cables to the Subwoofer Pre Out jacks on the Onkyo
Jul 20, 2015 | Insignia NS-HT51 Speaker
Replace fuse
Fuse on the sub can be removed by inserting a straight screwdriver and turning counterclockwise (unplug sub first). It should pop out. Replace with exact same fuse.
Jan 09, 2014 | Insignia NS-HT51 Speaker
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts total...so each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Insignia ns ht51 subwoofer the speaker is vibrating but with no sound i believe it is the fuse, if so which fuse do i need
If the fuse had blown the sub woofer would be dead. I think you have a very low frequency oscillation problem . Now the frequency is so low ( below 15Hz ) one cannot hear it but if you look at the sub woofer speaker it will be pushing like a piston - to and fro very powerfully.
You will need professional help on this one.
Apr 28, 2011 | Insignia NS-HT51 Speaker
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Got a red light on amplifire how do you reset amp I have an Insignia NS P2000 I believe with two 12-inch Insignia subs & I have a similar problem with the indicator showing that the amp is in protection...
Have you tried turning your gain down a little and then slowly turn the gain up while the sound is on!!!! There could be a pinched wire in you speaker wires!!!! Make sure your remote wire is not touching any metal or ground wire!!!!
Jan 18, 2009 | Car Audio & Video
Amp getting hot and shutting off
no mine do that and its pretty much normal
Jun 06, 2008 | Insignia 600W Bridgeable Amplifier with...
Car Audio & Video Logo
2,268 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
