Need to reset calculator
TI-34II CALCULATOR turns on with op error pressed reset button in back and now mem cleared
  • markant Apr 09, 2008
    Start over how, some keys will work but is there a code to start over.
    Problem Solver:
  • 9 Answers
When you press the reset button it resets EVERYTHING. You are now back at square one. Start all over again.
hamar nnelg
Posted on Apr 01, 2008
Where is the reset button on a TI-84
Instructions
Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command.
Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Aug 29, 2012 | Texas Instruments TI-84 Plus Silver...
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
Screen no longer works does not come on
Press [ON] and [CLEAR] at the same time to reset the calculator if
  1. Screen goes blank.
  2. Calculator does not turn ON.
  3. You get unexpected results (not due to YOUR errors).
Feb 02, 2010 | Texas Instruments TI-34II Explorer Plus...
How do i reset by TI 84 Graphing calculator?
Hello.
To reset all Ram press [2nd][MEM][7:Reset][1:ALL RAM][2:Reset][ENTER] , then press [CLEAR] yo claer the Ram Cleared Message.
If the extra programs that are loaded in the calculator are not archived they qill be erased.
Te reset the default configuration press [2nd][MEM][7:Reset][2:Defaults][2:Reset][ENTER]. Press [CLEAR] to clear meassage.
If you plan to do statistics, old lists will not be erased. This is the cause of many errors.
Hope it helps.
Oct 08, 2009 | Texas Instruments TI-85 Calculator
Texas Instrument TI-34II problem
Press [2nd] [LOG] to display the menu for logs and exponential functions. Select [LN]. Enter the (positive) number, close the right parenthesis and press [ENTER].
Oct 07, 2009 | Texas Instruments TI-34II Explorer Plus...
Cannot graph invalid dim error
This error show up when you are graphing out of the plot menu. If you are not graphing data points from list menu, you need to turn the plots off. In the y= screen, you will see the words plot 1, plot 2, etc across the top of the screen. If one of the plots is highlighted (black box over the words), you need to turn it off. This can be done by arrowing up and highlighting the box and pressing enter. When you arrow back down, the plot should be off and you will be able to enter an equation in the y= lines and graph.
If you are graphing from the plot menu, this error lets you know that one of the lists you are graphing is longer than the other.
Another way to fix the problem is to reset the calculator by pressing 2nd button then plus sign then 7 then 1 then 2. This will reset the calculator however if you are graphing from lists, your data will be erased. Hope this helps.
Oct 02, 2009 | Texas Instruments TI-83 Plus Calculator
Some segments of my calculator display are not showing up all the way, how can I fix this?
Try pressing [ON] and [CLEAR] at the same time to clear all memory and reset the calculator. That may fix the problem. If it is out of warranty, I am not sure it is worth fixing.
For repairs, contact Ti at ti-cares@ti.com (by e-mail).
Sep 27, 2009 | Texas Instruments TI-34II Explorer Plus...
Having trouble with my TI-83 plus
Some old junk is in memory. Reset the memory to defaults and everything will be fine. It is a good practice to clear memory before a new calculation.
To reset memory
Press [2nd][MEM][7:Reset][1:All ram][2:Reset] [EMTER] . Clear screen and enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Sloooooow....
Press the [ON] and [CLEAR] keys at the same time to reset the calculator. It may fix the problem. If it does not, change battery (if battery powered, not solar).
May 07, 2009 | Texas Instruments TI-34II Explorer Plus...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
