1977 ford truck 351 no spark to cylinders - Computers & Internet
    New Friend:
    Problem Solver:
  • 16 Answers
Your dura spark box has gone out. Google chevy hei conversion
its easy and works great and a lot cheaper
Posted on Nov 27, 2014
  • 57 Answers
Boorow a electronic ignition box from some one and plug that in or it could be pick up coil in distributor
Posted on Apr 24, 2009
  • 813 Answers
Hi friend
try chage ur spark plug
Posted on Apr 01, 2008
6ya staff
SOURCE:
I have a 1977 ford ltd 351 M it SKIPS,stalls won't stay running exaust seams to get hot on right pipe replaced carb pickup coil fuel pump control box plugs cannot figure this out.
Ron, if equipped with EGR valve try cleaning/replacing, check timing, check compression, do a leak down test if compression not to specs.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 30, 2016 | Ford Cars & Trucks
1977 351 Windsor motor and trans. was put in 1978 ford pickup and will not go in reverse after trans. fluid and strainer kit was put in. whats wrong
I dont like asking obvious questions but,did the trans work prior to installation and did you use type f fluid
Apr 04, 2015 | Ford Cars & Trucks
Ford engine 351 clevland v/8 no.starting with HS..........
the first letters show the plant the engine was made in.
Mar 11, 2013 | Cars & Trucks
1982 ford f150 351 firing order diagram...
Hi, the firing order is ( 1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 )
The distributor rotor turns COUNTERCLOCKWISE
The marked # 1 position on the distributor cap faces to the REAR and slightly towards the drivers side, the engine cylinders spark plug locations are numbered.
The wiring diagram....
Jul 11, 2011 | 1982 Ford F 150
Replaced distributor assembly-cap and rotor on a 1977 ford f100 truck-351 windsor engine-engine turns over real good but won,t crank
Check electronic control modual located on firewall. stick test light to negative side of coil turn engine over if it doesn't flicker then chamge magnetic pickup
Mar 22, 2011 | Ford F-100 Cars & Trucks
Need the diagram for the firing order of a 1977 351 modified
awcforever_7.jpg That should get it done for ya! Thanks. Let me know.
Mar 15, 2011 | Ford F-150 Cars & Trucks
Open Questions:
ARKANSAS 1/855+536/5666 Crypto tech support phone number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
TECHNICAL 1=855=536=5666 Crypto Tech support number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Computers & Internet Logo
107 people viewed this question
Ekse
Marvin
Marvin
