Question about Samsung Laser Multifunction Printer Toner Cartridge
Black spots of the left side of the print
I just started noticing that I was getting about 4 or 5 black spots on the left hand side of a print when it comes out of my samsung 2510 laser printer. Looks like a roller or something has toner on it. I looked , but i cannot figure it out.
  • itsmeagain2 Apr 01, 2008
    is that in the toner cartridge?
    Scholar:
  • 141 Answers
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
Posted on Apr 01, 2008
  • Patrick St-Jean
    Patrick St-Jean Apr 01, 2008
    It's with the toner cartridge....the drum normally is green or purple...
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
Spots along left side of page. On every printed page there are black spots along left side.
something on the fuser... is it the same distance from each spot every time?... then something is on the fuser roller, so it gets fused every time it rolls over that spot. thats my guess
Sep 08, 2009 | Samsung Office Equipment & Supplies
Black spots
It is in need of a Maintenance Kit. They are expensive, but usually come with good enough directions that you can do it at home ... if you are somewhat mechanically-inclined.
Jun 15, 2009 | Lexmark C520n Laser Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Apr 22, 2008 | HP LaserJet 4350 Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
Samsung Laser Multifunction Printer Toner Cartridge Logo
235 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
