Question about Fantom Titanium Hard Drive
Fantom Drive problem
Fantom Drive fell over and can not be seen by computer.
  • 1 more comment
  • sh3px1 Apr 13, 2008
    The drive cannot be recognized by my computer (Window XP). My guess is that the circuit board is bad. Where can I get the board replaced?
  • Anonymous Jun 19, 2008
    will not reconize the hard drive and has the same problem on other computers too!
  • chuckpare Sep 01, 2008
    Do you have to have software for your coputer to recognize a Fantom Titanium Hard Drive and if so where do I go to download it? Chuck
Try connecting it to a Windows XP Pro pc. Right click on "My Computer", left click on "Manage". Once the new management console opens, left click on "Disk Management". If the USB drive is recognized by the pc, you will be able to right click on it, and select "Delete Partition". WARNING: YOU ARE DELETING EVERYTHING ON THE DRIVE! Once it's done, right click on the drive again, and select "Create New Partition". Proceed thru the wizard that pops up, and format it. You will have a choice of using FAT32, but, if the partition is larger than 32 GB, it will fail (it's a Windoze limitation), so NTFS is your only choice, unless you use a 3rd party utility, Win98 (supports huge FAT32 partitions, 4 TB, I think), or Linux.(preferred). Good Luck, hopefully everything will work out fine. T-Power
Posted on Jul 20, 2008
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Sep 30, 2010 | Fantom Drives 120 GB Hard Drive
Hi, my dogs knocked my Fantom Titanium-II TFD500C16 drive off my desk and it fell to the floor on its side (no bounce, just a flat drop). Now it will turn on but it does not mount. No click of death, just...
After opening it up, was the 500GB disk-drive WARM or COLD to the touch? If WARM, the drive was spinning. If COLD, check that the drive is getting "power" from your USB port, or from the AC adapter.
Can you remove the disk-drive, and temporarily connect it to another computer, to see if it is a problem with the enclosure and/or the external power-supply, rather than just the disk-drive?
Is the disk-drive still under warranty ?
Original manufacturer's warranty?
Extended warranty purchased from the retail store?
Extended warranty offered by your credit-card company?
Oct 26, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
How do you install a fantom drive(titanium 2 firewire usb2.0.)or how do i psave programs to it.
You don't mention what kind of OS you're using - but either Windows, or OS X should see your drive regardless.
Before use:
Windows: Format the drive with NTFS.
Mac: Finder should pop up and ask you if you want to initalize the drive, you can choose 'yes' and continue.
Dec 02, 2008 | Computers & Internet
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom 1TB external USB drive failure, only half seen by MAC
the operating system may be corrupting format the hard disk drive the notice its behaviour
May 21, 2008 | Computers & Internet
Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
May 17, 2008 | Fantom Drives 120 GB Hard Drive
Fantom Titanium Hard Drive Logo
447 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
