Question about Whirlpool LGV4634JQ Gas Dryer
My Dryer does not heat
I have a Whirlpool dryer that is not heating. I have changed the ignitor, but it still does not heat. Please help.
  • corvera Jul 12, 2008
    I have change the ignitor, which is the thermal switch?
Have you checked the thermal switch? If this is bad it will run but give no heat.
Posted on May 27, 2008
SOURCE:
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Gas whirlpool dryer model LGR6611LQ0 will not heat up . Ignitor turns on but will not light
heatman101
Dec 19, 2010 | Whirlpool LGR5636L Gas Dryer
I have a LEN3434AWO Whirlpool dryer. Everything is working fine except there is no heat. Please help! Thanks!
heatman101
Nov 23, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Can't access the ignitor on my dryer.
Here is a video that will help you out click on sample video toward the bottom of the page..
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/Whirlpool-gas-dryer-not-heating.html
Sep 13, 2009 | Dryers
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
Jul 03, 2009 | Whirlpool WGD5300S Dryer
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Whirlpool LGV4634JQ Gas Dryer Logo
117 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
