Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Router not connecting to wireless comp
Recently we fixed our computer and bought a new Laptop. Our router works with the computer but will not connect to the laptop and we do not have the user id not the password to connect what can we do to fix the situation.
  • Belkin Master
  • 19,396 Answers
You need to activate your wireless network first
Posted on Apr 01, 2008
  • Ginko
    Ginko Apr 01, 2008
    You need to enter into router settings from Internet explorer. Typing the router IP (for belkin usually or, or
    then you are asked user name and password (admin/ 'blank box' or admin/1234 )
    Refer to your manual fro router IP and password.
    On router control panel locate 'wireless',
    Enable wireless network , and set 'Encription' To WEP 64 bits. You will be asked to put a key of 10 cyphers .
    It is the same encryption key that you will need to enter on the laptop.
  • Ginko
    Ginko Apr 01, 2008
    Here is the F5D8230-4 - User Manual - English
    Here is a wireless setup guide on a different belkin model, procedure is not much different.
No connection to wireless network
Is this an open wireless router or do you need to enter a security key code? Best get sp3 installed it also may fix this issue.
May 30, 2013 | Computers & Internet
It just stopped sending a signal and 5 hours later it started working then stopped when i tryed to lock it and now it wont work again all lights are on i reset it powered it back on prested the reset and...
The only computer I have is a Dell Insprion E1505 laptop and it is connected to a "COMCAST" cable modem. Windows XP, not Vista is installed. I purchased a LINKSYS WRT54G wireless router. I installed the setup disk and connected the modem to the router, and the router to the computer as step one, but when step two had me disconnect the router from the laptop so it could connect via wireless network, it just says "easylink advisor could not establish a wireless connection with the router
two laptops, a desktop PC and my son has Xbox live. I recently bought the Linksys wireless-g router with speed boost and that didn't work. If any of the laptops were on, the other wouldn't work and my son's Xbox live would lag. I was thinking about exchanging it for the Linsys wireless-N broadband router but then I read the reviews and they were horrible. I need something of that sort but something that isn't known for being unreliable and dying.
I bought the Turtle Beach X41 Headset, and it is causing some problems with my wireless connection. Due to a number of reasons, it is not possible to directly hook up my 360 to my modem. So, if I bought a new router that can operate on a 802.11a frequency, would that help or not? My current router is a Linksys Wireless G, 2.4GHz, router. Microsoft has said that an 802.11a frequency router could fix problems with other wireless electronics. If it would help, which router should I buy? I've read a few reviews for the Linksys WGA54AG 802.11a, and everyone says it doesn't work good. Any suggestions on another brand
i tink with these you can do some thing
Dec 19, 2010 | Linksys Wireless-G WRT54G Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
I recently bought a linksys wireless router i've
Make sure your wireless feature is turned on on the computer. There may be a switch on the edge of the computer somewhere, you don't say what kind of computer it is.
Find the wireless connection wizard on your computer and run it. Find it in your network folder in the control panel.
If this is too much, post a comment to this question and we will back up and start over.
BTW, if your laptop has a ethernet outlet (looks like a big phone jack), you can wire your laptop to your router.
I want to help you with this problem
Dec 08, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
