Question about Mitsubishi ColorView XL30U Multimedia Projector
RESET LAMP HOURS
WE NO LONGER HAVE THE MANUAL FOR OUR XL30U PROJECTOR AND WE ARE CHANGING THE BULB.....WHERE IS THE MENU WE NEED TO ACCESS TO RESET LAMP HOURS?
  • Anonymous Mar 15, 2014
    I have an Optoma Pro800P and I cannot reset the Lamp usage....when I access the Option Menu then Lamp Setting, the only information is the lamp usage and the menu freeze....I need to unplug the power to be able to use the projector
  • 563 Answers
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Posted on Apr 01, 2008
SOURCE:
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Replace lamp for NP-M300W
trun on the projector
menu-reset-clear lamp hours
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Feb 05, 2014 | 3M (EP7640ILK) Projector Lamp for MP7640
My Optoma TX780 projector is not working and all the indicators ie, Temp, Power and Lamp are on. I have changed the lamp though and it worked for a while then the lights came on and would not come on.
you need to reset the Bulb Hours in the on screen menu. it turns off because the bulb contains mercury and after a certain amount of hours the bulb will burst, spreading mercury every where. reset the bulb hours and it should stay on.
Jul 03, 2011 | Optoma TX780 DLP Projector
I just got a new bulb for my projector. it was fitted as per the instructions, and looked undamaged on delivery, but after about 10 min of viewing, the hight temp alarm sounds and the projector shuts...
hi,
Did you rest the lamp hour after replacing the lamp. It is recommended the you have to reset the lamp hour after replacing the lamp. For resetting the lamp hour do the following.
1. Power ON the projector
2. Press the Menu button
3. Select OPTIONS
4. In OPTION menu select Lamp Reset and press the enter button.
(If the lamp hour counter is at the heights level then the projector will turn OFF after some time.)
ok
Apr 28, 2011 | Optoma EP1690 DLP Projector
I recently changed the bulb in the projector with a new bulb but after changing it it now says the bulb is at 0 % and no longer works. Is there a reset button we may have missed when changing the bulb?
to reset the lamp hours,
simultaneously press down the bottom right MENU/HELP button, and the centre ENTER button and the centre bottom DOWN ARROW button.
Then with a spare finger press the top left STANDBY/ON button.
LAMP 0000H should be displayed. it is now reset
Feb 28, 2011 | Sharp PG-MB56X DLP Projector
We have had this projector for 2 years. The projector will not turn on. It will turn green for 3 seconds then turn red and the lamp light turns red. I feel like the lamp could not already be worn? I was...
Whether or not you need to replace the lamp depends on how many hours of use it's had. You should be able to find the lamp time somewhere in the menu on the projector. Lamps for this projector are rated for 2000 hours (bright mode) or 3000 hours (Eco mode). In my experience they usually need changing at approx. 1500 to 1600 hours (bright mode). On Page 54 of the owners manual ( http://www.projectorcentral.com/pdf/projector_manual_4177.pdf ) are instructions for changing the lamp and zeroing the timer once it's changed. The lamp is Type number : DT00911. You should be able to get one from the manufacturer, the dealer you purchased the projector from, or specialty bulb and lamp stores. Be prepared. They aren't cheap, but it's better than having to buy a new projector.
Jan 14, 2011 | Hitachi CP-X450 LCD Projector
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Sep 25, 2008 | BenQ MP610 Multimedia Projector
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Mitsubishi ColorView XL30U Multimedia Projector Logo
1,031 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
