Question about Frigidaire FEF336BC Electric Kitchen Range
Re-program range does not operate,F9 requires unit to be re-programmed.how do i do that?
    Novelist:
  • 184 Answers
TRY UNPLUGGING THE RANGE FOR ABOUT 5 MINUTES.
THEN PLUG IT BACK IN AND SEE IF IT RESETS. SHOULD COME UP WITH PF FOR POWER FAILURE. PUSH CANCEL AND REPROGRAM THE TIME OF DAY. THEN CHECK TO SEE IF THE OVEN WILL WORK. IF NOT, REPLACE THE CONTROL.
Posted on Apr 04, 2008
F9 error code
Hello. F9 is a fault with the oven door locking assembly. Either the motor or switches that the lock uses to operate have failed, OR the clock or oven control has failed.
Apr 08, 2014 | Whirlpool WFE320M0AS 4.8 Cu. Ft. Electric...
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Jenn-Air JGR8855 oven light stays on
F9 is for the door lock relay fault. Does the lock work OK? Is anything else acting funny on the unit?
Nov 22, 2012 | Jenn-Air JGS8750 Gas Kitchen Range
I have a Whirlpool Duet GHW9150P that stops at the end of the spin cycle with a code f9 e2, When it is run empty no error, with a med to large load it faults out. 1 month old!
erwr
wer
Sorry to read about your problem, I hope this helps you out.
F9 means an overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Self clean cvode F9
Hello there:
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
replace parts as necessary
May 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
F9 code
says F9, is a problem with door lock saftey circuit. replace power relay board
Mar 01, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Code F9
Lock motor relay watchdog is active when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Dec 15, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
108 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
