SOURCE: I have a red streak on the page coming from my HP
look at the green roller and see if you have shots on the green surface, remember if there is a hit or a line, this will be marked exactly the same on the sheet, and are usually small so as describe reviews all the green cylinder, finger Giral in search of imperfections on all surfaces, if you find them, but here you do not have anything to do, you must replace the entire cartridge cleaning (half of the cartridge in which roll is green) or alternatively, the entire cartridge.
http://www.uninetimaging.com/newsletter/HP_2600_Reman_Eng.pdf
Now, if you do not find that surface damage, open the cartridge (above are instructions on how to do ", to which sections the cartridge into two halves (the waste hopper and toner hopper new) clean with a solplador of air or a vacuum .... rodillito has an emphasis on black that makes the green roller rolling.
It is counter intuitive what I'm saying but if you read the manual while watching the disarmament of the cartridge you'll realize it's true.
NO SIDE SPOTS UNIFORMS
The lateral blotches are produced because the waste hopper is full of waste toner (waste chute is located detráz green roller DRUM) this happens when we have printed enough, the magazine is full and the toner, this roller is not can take, so to clean the hopper can do the following: a) with an air blower introduces air between the roller and the plastic to remove the toner. b) it is best to cut a hole in the center of the housing that protects the wiper blade (above) and proceed to dump all that excess toner out there. is closed again with adhesive tape and ready.!
