Question about Dualit CTS4E 4-Slice Toaster
Need local service for my toaster
The heating element on our toaster is no longer working. My son stuck a metal knife into the unit while it was plugged in. He is fine, but he toaster is not. There was a big spark and no more heat. I need to find someone to fix it locally. I live in a suburb north of Chicago. Any suggestions?
  • Anonymous Jul 02, 2008
    coils won't heat
  • 51 Answers
Hi Ordon,
Use the following link to find an estimate to repair your toaster.
http://www.fixya.com/Services.aspx?ctgid=161&zip=60601
Thanks.
Posted on Nov 02, 2008
SOURCE:
Heating element on toaster oven have mercury in them
No they don't. If they did it would be online and they would never get through inspection anyway. Mercury is expensive, but you do find mercury in all florescent tubes and compact florescent lamps in very small quantities. Toaster oven elements are radiant and have a metal element inside a ceramic glass tube.
https://www.google.ca/search?q=Heating+element+on+toaster+oven+have+mercury+in+them&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=bokqWOz-NoWN8Qe66IegDw
Heating element on toaster oven have mercury in them Google Search
Nov 15, 2016 | Toaster Ovens
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
Only the side elements are working on the toaster. The middle elements which would toast one side of a slice of bread are not working. Is it possible to repair/replace the middle elements?
Maybe. Unplug the toaster and remove the bottom plate as you would for cleaning. look for the wires connected to the middle elements and see if one has become disconnected or broken. If one or more of the connections to the middle element is a quick disconnect type (click link for a picture),
https://s16-us2.ixquick.com/cgi-bin/serveimage?url=http%3A%2F%2Fts4.mm.bing.net%2Fth%3Fid%3DJN.EnzjOARZwnQZZjF7oGU2Dw%26pid%3D15.1%26f%3D1&sp=5dc5e8fde9f2f3462b6483c20bb42f01 then inspect it for overheating, oxidation or corrosion. You may be able to clean it up with a Scotch-brite metal polishing pad.
On my toaster, the connections to the heater elements are metal strips riveted to tabs from the element assemblies. One strip is riveted to the power neutral; the other has a quick disconnect tab for a wire from the thermostat. A loose or broken rivet could be the problem, but do not use an aluminum pop rivet to repair it. It can't take the heat, even if you could find one small enough.
I've seen toaster heater elements evaporate over the years - they get a hot spot, which burns off metal, making it thinner and hotter until finally there's nothing left there. At that point the element is gone. I suppose if you could find nichrome ribbon wire of the same width and thickness as the original, you could rebuild the heating element plate, but it would be a delicate task because the mica insulating material is fragile. It's probably more practical to scavenge a working heater assembly from another toaster of similar design, if the electrical connections are serviceable with the tools you have.
Unless this is a very fancy unit, it's probably cheaper and easier to scrap it out and replace the whole thing.
Jun 26, 2015 | Bodum Kitchen Appliances - Others
Toaster lever stuck in down position
I just fixed my Breville CT75XL Ikon 4-Slice toaster which was stuck in the on-down position. Wife said it heated up the whole kitchen and finally unplugged it. There are tamper proof screws as well as needle nose pliers needed to disassemble what appears to be a unit that is not intended to take apart or service. All I did was release the mechanism that holds and powers on the device then scrape the metal contacts with an emery board. Unit works but this buys me time to find a replacement. It won't be another 170 dollar disposable Breville made in China that's for sure. Only got 3 years 4 months use, family of 2, which is pathetic.
Aug 16, 2013 | Dualit Kitchen Appliances - Others
Elements not heating
Buy a new toaster. Very cheap appliance.
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
Toaster no longer heats. Can I purchase the heating element and install myself?
mcdevito75 here, Chances are the heating elements are soldered in on the toaster and may take special tools to fix, if the heating elements sre burned out, maybe better to get another toaster.
Jun 19, 2010 | Dualit Vario 2 Slices Toaster
Out Dualit toaster keeps blowing the fuse. It's
Probably one wire Loosen up or a wire from one heating element have cut off and is contacting the metal body of the toaster. You need a good visual insect of your toaster, you may use a flush light to see inside the electriacl elents and also open the bottom base to insect the wire conections to the heating element.
I beleive one or more heating elements is the problem and you need to replace them.
Good Luck
Feb 01, 2010 | Dualit CTS4E 4-Slice Toaster
Back to Basics TEM-500 toaster no longer heats up
We have the same problem after only about 20 uses. The customer service number is 1-800-688-1989...we may be able to get it replaced. If they aren't willing to do anything, I'm thinking of filing a complaint with our state Attorney General because there are SO MANY complaints of the SAME, idential problem from thousands of consumers!!!!
Jan 02, 2010 | Back to Basics TEM-500 Egg & Muffin...
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Lower Heating element will not turn on
take notice of the local repairers
if they say parts are hard to come by , a DIY will have even more trouble
junk it and get a new one
Nov 24, 2017 | DeLonghi EO1258 - Stainless Steel Toaster...
Dualit CTS4E 4-Slice Toaster Logo
204 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Ross Keen
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
