Viewsat no power
When i load new pin machine no turn on ,i turn off power by removed power cord and machine can not on off funtion
I used pc to down load again ( only older pc , it has old conection from pc to viewsat. You must buy a cable by viewsat company about 5$ ). because with usb key it can not push machine working
thank a lot
Posted on Jun 03, 2008
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
No manual ...no power- how do I work this machine? I'm able to lock/unlock it
THIS IS THE ONLY THING YOU CAN DO
Check that the unit is plugged into a working outlet and for
blown fuses.
This must be done by a THECHNICIAN SPETIALIST
Unplug washer or disconnect power.
Check continuity of line cord and line fi lter.
Check harness connections to CCU.
Plug in washer or reconnect power.
Check the touch-pad/LED assembly by selecting different
cycles and changing the modifi ers and options available to
confi rm the touch-pad/LED is responding.
Unplug the harness to UI and check with a DVM or VOM on
Connector UIP3 if correct voltage is present.
Pin 1: -5V
Pin 2: 0V (connection to Line or neutral is present in
normal operation).
Pin 3: -12V
If voltage not present and CCU is powered correctly (line
cord and linefi lter has continuity) the CCU is broken.
Disassemble the UI and check harness to UI and
Interconnection on UI between Center and Right Board.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Power off viewsat
while loading a new file it stuck and I keep it power on.
what should I do now?
May 17, 2008 | Audio Players & Recorders
VS- FTA
For the Viewsat Extreme we re-loaded the newest fix, and voila all problems were corrected. Can use front panel, and remote works geat.
Apr 25, 2008 | Audio Players & Recorders
Viewsat ultra 2000
I would suggest to try to use the NULL cable and do the following:
1.Load VSULTRA_v117_factory_bin.pgm
2 Load DBPSW-061127U_A.PGM
3 Load the latest xxxxxx-xxxxxxU pgm file.
You will know where to find those programs.
Good Luck.
Feb 07, 2008 | Audio Players & Recorders
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Fta viewsat extreme dead.
I am using viewsat extreme 2000. After downloading the new program PC-STB. Front panel power has gone. Only rear light on. All view has gone.
Would you please send me by email, how can I solve this problem? I shall be grateful if you please reply.
Thank you.
-Rajesh
rkb@295.ca
Dec 11, 2007 | Audio Players & Recorders
Viewsat ultra reciever has no power/lights etc.
OK I did my research. Apparently there is a little chip inside the receiver that has burnt. We need to take our receiver the the people who know how to fix them and replace the chip with a new one. It might take time as from what I hear it could be any chip? Hope this helps
Dec 08, 2007 | Audio Players & Recorders
ViewsaT CODES
no sound no vedio and the dollar sign is highlighted
Nov 02, 2007 | Audio Players & Recorders
Viewsat platinum
make sure the receiver is off using the switch on the back. connect serial cable.. open unloader program on computer, pick the bin you want to upload. click pc to stb.. after the slide bar appears turn of the viewsat... it should start to dl now.. wait.. when the computer says finished, don't turn off the viewsat yet. the viewsat will auto start.. if it doesn't wait till the software is finished ,, the screen will come back to a channel.. If no picture go and set up the antenna.
Sep 20, 2007 | GPS
131 people viewed this question
 Grubhead
Grubhead
