Question about Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive
Dell D600 LCD screen turns on but no LCD picture anymore
Hook up a CRT to the vga connection on the back of the laptop. Reboot, and press the Fn+F8 key and see if you can view your desktop on the crt. I am dealing with the same issue, but i noticed that i can make out just barely on the LCD my image of the desktop. In researching, it appears that either the inverter is bad or the backlight. Both appear to be very inexpensive to replace but requires some soldering experience. If you wish to give it a try, just look up www.lcdparts.net.
Also goto www.discountparts.com and see if they have a replacement/used LCD screen. That SHOULD be easier to replace.
john
Posted on Apr 18, 2008
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
I turn my Dell Latitude D600 laptop on and startup screen shows as usual but then it goes to a black screen. Can you help?
If your computer keeps on running after it turns black the problem maybe is the LCD. However if the computer is not running after it went black then possible problem is with the MOBO (Mainboard)
Hope it helps.
May 13, 2010 | Dell Latitude D600 Notebook
Finding compatible replacement LCD for my Dell Latitude D600
Since you will need to open your computer and remove the screen to replace it, I suggest you remove it now and look up the part number on it. Then you'll now exactly want part you laptop has.
Alternatively, you can also get a copy of SiSoft Sandra and run it. It should give you the screen make and model
Mar 25, 2010 | Dell Latitude D600 Notebook
My laptop dell latitude d600 turns itself off its screen and fan
If your laptop with battery is OK
That is because the adapter connect to power is not very firm.
My inspiron 1520 LCD screen also has this problem, I change the adapter and Patch board . so it work fine now.
If your laptop work with battery also have this problem, it maybe caused by power supply system setup.
Apr 30, 2009 | Dell Latitude D600 Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Wanted: replacement display screen - Samsung 14.1"
HI
You can buy from any of these.
http://www.google.com/search?rlz=1C1GGLD_enIN307&aq=f&sourceid=chrome&ie=UTF-8&q=D1002+dell
I have got almost 3.
Shopping results for D1002 dell D1002 - Dell Latitude D600 LCD Screen $149.97 - Renwerx Tech DELL D1002 LATITUDE D600 SXGA+ 14.1 DIS $253.75 - codemicro.com Dell D1002 LCD 14.1" TFT SXGA+ LATITUDE D600 $488.75 - eBay
Do let me know if you need further information. Its pleasure to assist you. And let me also inform you that can call Dell Spare Parts Sales and ask them to get this one for you. You get 90 days of warranty as well.
The part number is D1002 for the monitor.
Thank you
Rakesh
Dell Expert
Jan 06, 2009 | Dell Latitude D600 Notebook
LCD
1. Plz replace the HT unit.
2. Replace the LAMP of LCD.
Mar 10, 2008 | Dell Latitude D600 Notebook
Display not working properly
You should be able to plug in an external (Desktop type) monitor . Look for a connector on the side or back of the laptop. If the external monitor works, you have pretty much diagnosed that you have a LCD problem.
Ron-
Mar 07, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 1150 Latitude D600 14.1 LCD Display-LP141X14 CD-ROM Drive Logo
319 people viewed this question
Alun Cox
