Question about HP DeskJet 845c Printer
Crppy Printer While printing, it stops then goes again in a few seconds which slows it down. Is there a way to fix this or is it time to get a new printer?
  • Cory5468
    Cory5468 Apr 12, 2008
    Yeah it is pretty old, this action happened once.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
It must be an old printer or it is low on ink but i would say get a new one :)
chris
Posted on Mar 31, 2008
How do I fix my printer?
throw it in bin
check you pc memory also
May 05, 2016 | Office Equipment & Supplies
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Our HP Laserjet P4015N printer prints slow. It prints, stop, prints, stop and so on. It is working from a print server (Windows 2003) and we have update the driver. It might work for a day, but then it...
If it is a local issue to your printer it is likely that the fuser temperature is set to low. If the fuser temp is set low then it will pause printing in order to maintain a whatever temp it is set at. If you web out to your printer(type in the ip address of your printer) you will find the menu for the printer. Somewhere in there will be the option to increase or decrease the fuser temp. Sometimes it is as obvious as FuserTemp;Higher, HIgh, Normal, Low, Lower. Other times like on the cp2025 color laser i have it is under the extended print modes option, and it is under fusing with the options of; less fusing (-2), less fusing (-1), normal, more fusing(+1), more fusing (+2). however the option is presented on your printer you will want to increase the fuser temp. do it incrementally and see what works best from you. If this does not solve the problem there may be a problem with the spooler dropping packets from your print server. Hope this helps.
Jun 09, 2011 | HP LaserJet P4015N Printer
I have a Kodak ESP5 all in one printer. At first
Call 1800 421 6699
Printhead needs to be replaced.
It free of charge replacment
Feb 13, 2010 | Kodak ESP 5 Printer
Its not responding and the warming up sign flashing for along time
Mine will do this... sometimes even after I just printed something! Sometimes I fix it by canceling the print job and then turning off the printer. Wait a few seconds and turn the printer back on then try again and it usually works. Other times all I have to do is "open" the printer as if I was going to change the ink cartridge and when I shut it back down, it will print without any more problems.
Oct 06, 2009 | HP PSC 950 All-In-One InkJet Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Network copier printing very slow when printing bulky document
turn collate off the printer will treat each page as a separate job slowing the machine down.
Apr 25, 2009 | Ricoh Office Equipment & Supplies
Canon S300 do not print at all???
Slow printing and ink problem are not relate I think.
Ink as you say is lack of use and drying out -and the remedy cures that.
Slow printing is more to do with the computer not passing the info quickly enough from the data store[called print spooler]
This could be because you have other programs running and the resources are taken up.
So What to do.
Uninstall the printer software.
Restart the computer
Come off line
disable the anti virus software
Reinstall the software.
Make sure there are minimal programs running else where when you go into print mode
Jul 27, 2008 | Canon BJC S300 InkJet Printer
HELP printer is haging up computer
To me, it looks more as a network problem rather than a printer problem. Just to make sure, delete every unused printer drivers from your computer, including the SCX-4521f. Unused printer drivers take up memory and CPU resources of your computer, even if they are not being used. The second common issue on slow computers is an excess of installed fonts. If you have more than 300 fonts installed, you need a cleanup.
Finally, install the SCX-4521 as a local printer only on your computer and print some tests. If they come out at decent speed, get a real computer technician to diagnose your network. If it doesn't, you need to further clean your computer's registry. It is most probably loading drivers, data and files from deleted applications. You can download a very good cleaning utility called Ccleaner on the Internet. Also check for possible virus using Panda or Kapesky antivirus. Good luck.
Oct 26, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP DeskJet 845c Printer Logo
16 people viewed this question
Ben Johnson
