Question about Samsung PCL545R 54" Rear Projection Television
SAMSUNG PCL5415RX-XAA - Audio OK, but screen is dark, has no images.
Hello everyone,
I have a SAMSUNG PCL5415RX-XAA since 2002, it has been a great TV but now is showing some flaws.
First the image was all green and then it went blackout, several trials later to turn it on again I can heard the relay clicking, but the TV powered off right away, then I thought that something shorted.
After reading some of the threads on this site, looks like it could be that any of the boards are indeed shorted; so I opened the TV set looking for signs of fluid leaking, but I didn't find any, then I just blew the dust off and tried again.
Now the TV turns on and stays on, and it has audio, but the screen still dark, it has no images.
I'm troubleshooting following the flow charts on the service manual page 5-3, titled "No Raster (Sound OK)", I pretty much understand all of the steps except for the first one, "Check Heater"; on the wiring diagrams I have seen the a couple of lines marked as "Heater", but it is just a line, it doesn't relates to any electronic component.
What is the "Heater"? Is this "Heater" the same as the heat sink?
If so, what should I check on the heater (heat sink)?
Any recommendations to help find the delinquent components?
Any help will be greatly appreciated.
Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
The heater is a small fan in side the tv it may be cloged
Posted on Mar 31, 2008
Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 30, 2015 | Samsung UN65C8000 TV
How do I fix a Samsung tv model htp5054x/xaa? I have power and I can hear audio but no image.
First trouble shooting steps is to try a different source, or at least a different cable. A bad HDMI cable can allow sound but not image. Also look closely at the screen. If you can see a dark image, it would indicate that the lighting system has failed. Check this video for some tips. Samsung Plasma TV Repair How to Repair and Replace Main Board
Sep 07, 2015 | Samsung Televison & Video
Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 31, 2017 | Televison & Video
Dark screen on samsung lnt4669fx lcd tv, what could be the problem?
As you suspect, it might be of T'Con board fault. Check all the flat cables connected to T'Con to panel should be checked first for any loose contacts. Re-seat them once. If you wish to know more, check this site. It has illustrations of screen shots, for Samsung LCD TVs, with a faulty T'Con board. Can compare these images with your TVs.
Jan 24, 2013 | Samsung LNT4669 TV
Need owners manual for flat screen samsung LN32B36065D. having problems with televsion. no manual with tv when purchased.
Hello
To which model Samsung TV do you want to get the user manual? You have here stated two models of Samsung. If it is for Samsung LN46C630; I've the manual with me. If you send your email address to me, I'll send a copy of it to you by return mail. There is no model Samsung LN32B36065D with Samsung website. OK.
Jun 15, 2011 | Samsung LN46C630 TV
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I Have a Samsung flat screen ser# LNS4692DX/XAA that video went out and went to dark blue on all channels,still have good audio but cant even get a menu screen any suggestions?
Unplug tv from wall socket for minute to get it reset, replug back in and turn it On
Do you get Menu screen now or tv shows channels?
If problem still not solved then let me know how old is this tv and any related info about problem like storm or lightning in area that caused this problem in tv. Does tv show picture in dvd playback?
Thanks.
Nov 04, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Oct 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Samsung PCL545R 54" Rear Projection Television Logo
236 people viewed this question
Henry  Thomas
Henry Thomas
