Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Have the samw problem - computer worked yesterday, went to turn it on this morning and it won't start. The green light is on on the motherboard. I've checked all of the connections, everything seems to be fine.
How did you determine your motherboard was bad?
  • Lori3867 Apr 12, 2008
    I have the same exact problem.. The computer won't turn on but there is a green light in the back..
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Posted on Apr 13, 2008
Hello
I have a dell dimension 5100 the light in the mb is green but the one in the on off button is amber will not start at all have any help for it
Posted on Dec 05, 2008
SOURCE:
Computer won't boot
Check if the connection between the wall outlet and the computer is fully plugged in. If it's good, maybe there's a problem inside the computer. Open your computer and make sure everything is plugged in correctly.
Sep 28, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Hello, the green motherboard light on the computer
If there is no loss of functionality then I would say no.
Sep 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Monitor and Mouse not working
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
Jul 16, 2008 | Dell Dimension 4600 PC Desktop
5100 problem
Hi
To help you troubleshoot a problem, your computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
Reply with the Power Button light and the Diagnostic lights color and sequence for further assistance.
Advanced Troubleshooting and Owner's Manual
Mike
May 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. [email protected] Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
3,994 people viewed this question
Ekse
Clive
Clive
